Bike No start, any Ideas?
Old Dec 15, 2011 | 03:05 PM
TSD's Avatar
TSD
Thanks Guys, I will pull the codes tonite and clean it to see if it helps, it seems to be worse when its cold outside, when its warm it cranks fairly easily.
Old Dec 15, 2011 | 05:37 PM
TSD's Avatar
TSD
Checked codes, it has five, they are:
23-front fuel injector
24 front ignition coil
25- rear ignition coil
32- rear fuel injector
41- crank position sensor
WHAT THE HELL? Is the crank sensor causing all of this? Please help!!!
Old Dec 15, 2011 | 05:45 PM
PostmanII's Avatar
PostmanII
ignition switch
Old Dec 15, 2011 | 08:05 PM
TSD's Avatar
TSD
Anbody else think I Need an ignition switch?
Old Dec 15, 2011 | 11:42 PM
larsfum's Avatar
larsfum
I doubt that it is the ignition switch. Yes, the CKP (Crank position sensor) could be causing all of those codes, but it still may not be that. As stated before, check the battery. Autozone will do free battery tests. Check to see if you are getting spark. If no spark, Do you have a tuner on it? If so try taking the tuner out of line, and see if it will then start. If not, my vote then is the CKP.
Old Dec 16, 2011 | 12:25 AM
Dustball's Avatar
Dustball
Sounds like a Crank Position Sensor to me too. Your trouble codes tell the story...
Old Dec 16, 2011 | 11:33 AM
Moe55's Avatar
Moe55
If the CKP is not working the ECM or Turner does not know the engine is turning over so there will be no spark.
All your codes lead you to a bad CKP.
Old Dec 16, 2011 | 12:04 PM
trackadaptor's Avatar
trackadaptor
Read watch Video: https://www.hdforums.com/forum/elect...ensor-bad.html
Old Dec 16, 2011 | 05:01 PM
larsfum's Avatar
larsfum
Originally Posted by trackadaptor
Read a little further down in that thread and you will see that the CKP needs to be connected while doing that test. Still a good video of what a bad CKP reading would look like though.
Softball LMDM
Apr 29, 2019 06:50 PM
Fatboy 1993
EVO
44
Feb 1, 2016 07:57 PM
ArtR
Jul 7, 2014 09:19 AM
Johnny Sotelo
General Topics/Tech Tips
Jun 26, 2014 12:55 PM
77ironhead
Ironhead
Jun 18, 2007 04:03 PM
