Help, fried something...
Old Dec 17, 2011 | 04:10 PM
mkguitar's Avatar
mkguitar
Hmm, you have some electrical smarts to get this far- and you understand the starter circuit better than 95% of riders.
It is possible this fault is unconnected ( pun) to the jump start attempt
( BTW use a battery charger on a dead battery- the charging system on the bike can be stressed and fail trying to revive a battery.)
continue to check for power to the starter relay.
in the short term if this gets wacky and you start to realise that the TSSM ( in the fairing)- you could always get a replacement end cover for the solenoid that has a button on it---about $24 and will always get you going.
Mike
Old Dec 17, 2011 | 04:41 PM
taoshum's Avatar
taoshum
3rd Gear
Default Solved????
see original posting, modified.
somehow, it is solved.
Old Dec 17, 2011 | 05:35 PM
user 8373900's Avatar
user 8373900
It's OK you know, most of us have forgotten the kill switch even if only for a few seconds..
Mark
Old Dec 17, 2011 | 07:24 PM
taoshum's Avatar
taoshum
3rd Gear
Mike
I think I'll get one of those covers with the button! Now that I know enough about it to use it. Thanks!
Old Dec 17, 2011 | 07:55 PM
mkguitar's Avatar
mkguitar
Many, many electrical faults are bad connections, disturbing the wiring as you did will often fix.
you may want to take the time to go through and clean the connections- if you use contact cleaner spray -SOME EAT PLASTIC- read the can.
I use the "nick-sand" pen found at auto body repair section autozone etc. it is a "pen" with fiberglass which cleans up the pins and sockets.
dieelectric grease to keep moisture out
here's a cover- not this particular one- I just did a quick google so you could see it
http://www.debrix.com/Solenoid-Cover...p/17762-m1.htm
mike
Old Dec 17, 2011 | 08:38 PM
fenderzig's Avatar
fenderzig
Glad you got it working again....
Old Dec 18, 2011 | 04:04 AM
SpiderPig's Avatar
SpiderPig
Good to hear that its now working. HOWEVER I would be willing to bet that if it "amazingly just started" it will once again, "amazingly not start" once again. And at the worst possible time. Something was the cause, and I would want to know what that was.
Old Dec 18, 2011 | 09:48 AM
Jackie Paper's Avatar
Jackie Paper
Glad you got it working. TSM is the turn signal module / bank angle sensor, turn signals and if bike drops turns off motor. TSSM is that plus alarm. It's located in front of rear tire under the cover on a Softail. See were the pigtail is and the two clips were the alarm goes. TSSM is directly above. The starter circuit breaker is above that.
chargerjoe
May 9, 2014 10:48 AM
JT-FXDL
Sep 7, 2012 10:53 PM
lowglide88
Jul 8, 2011 10:16 AM
Reino_79
Apr 14, 2011 05:24 PM
1150A
Feb 6, 2011 03:40 PM
