torque wrench
Old Jan 1, 2012 | 04:03 PM
  #51
djack's Avatar
djack
I had a snap on 3/8 drive 0-200 in. Lbs. sent it in for calibration after I broke some screws with it. They returned it said it was rusty and non repairable. So I don't recommend keeping torque wrenches on service trucks
Old Jan 1, 2012 | 04:47 PM
  #52
flashracer's Avatar
flashracer
I use the HF torque wrenches. I hope they are close to spec.
Old Jan 1, 2012 | 05:00 PM
  #53
Nirvana's Avatar
Nirvana
Originally Posted by murph
I was in a similar situation. I did some research and found that CDI torque wrenches are made by Snap On.. So i bought two. One in in/lbs, the other in ft/lbs... The work just like the more expensive Snap On ones. They work great. Here is link to their website.
CDI Torque Wrench
CDI seems to be a promising recommendation. The selection of wrenches doesn't seem quite as bewildering as some other brands. Let's say that I wanted one in-lb and one ft-lb wrench, which of the following would be preferred choices?
1501MRMH 20-150 in. lb. 1/4"
2002MRMH 30-200 in. lb. 3/8"
2502MRMH 30-250 in. Ib. 3/8"
1002MFRMH 10-100 ft. lb. 3/8"
1503MFRMH 20-150 ft. lb. 1/2"
Old Jan 1, 2012 | 08:08 PM
  #54
murph's Avatar
murph
I have these two models. They work great.
1502MRMH 20-150 in. lb. 3/8" 1 2.8 - 15.3 .12
and
1503MFRMH 20-150 ft. lb. 1/2" 1 34 - 197 1.4
With these I have full range of all possibilities needed. Here are some prices for you.
1502MRMH 20-150 in/lbs $109.95
1503MFRMH 20-150 ft/lbs $137.95
I hope this helps. I love these wrenches. Really nice quality.
Old Jan 1, 2012 | 08:14 PM
  #55
fabrik8r's Avatar
fabrik8r
Google around a bit there are several homemade calibrating devices that can be made rather simply
Old Jan 1, 2012 | 11:13 PM
  #56
Nirvana's Avatar
Nirvana
and
Yes, it would be better to have the in-lb wrench in 3/8" drive.
Old Jan 4, 2012 | 03:50 PM
  #57
iclick's Avatar
iclick
Originally Posted by djkolp
A $19.99 Harbor Freight Torque wrench more accurate than a $300 Snap-on? I went to the HF website to check out the reviews, and there were quite a few "I snapped the bolt off" using this wrench. I'm glad you've had luck with your HF wrenches, but I wouldn't use a $20 torque wrench on anything other than a lug nut.
I think if you snap a bolt off using any TQ wrench you don't know how to use it, as if anything you'd have at least a vague feel for the TQ you are aiming for. If the wrench doesn't click I would think you would stop before snapping a bolt off, which would take quite a bit of force. You really don't know what their procedures or issues were, and the incidents may not be the fault of the wrench. Anyway, no problems here and others who have reported in here in a number of previous threads haven't made any negative points about them.
Anyway, over several decades of wrenching on various things I've found that there is no direct correlation between cost and quality.
felix27
Jun 22, 2016 11:34 PM
ed parolini
Jun 14, 2012 10:01 AM
sjp3003
General Topics/Tech Tips
Jun 18, 2011 12:18 AM
trozenhorse
Dec 1, 2009 02:05 PM
txHarleyMan
Mar 16, 2005 11:28 AM
