Internal wiring questio
Old Dec 29, 2011 | 12:52 PM
frankiefire702's Avatar
frankiefire702
Default Internal wiring questio
Just a quick question guys. Im about to do apes on my sg. Did you guys cut the rubber casing of the wire budle before running them. If so did you wrap the bundle in heat shrink or electrical tape before running them?
Old Dec 29, 2011 | 01:06 PM
slothy's Avatar
slothy
all the bars ive done always kept sleeving on. i just taped the open edge to it wouldnt get caught on anything pulling the wires thru.
Old Dec 29, 2011 | 01:10 PM
dbell66253's Avatar
dbell66253
I kept the rubber on and used wire pulling lube to make it easier.
Old Dec 29, 2011 | 01:28 PM
frankiefire702
Thanks guys. Is it easier to pull the tbw through first or the switch wiring first?
Old Dec 29, 2011 | 01:30 PM
slothy's Avatar
slothy
i did both at same time (se tbw sensor)
Old Dec 29, 2011 | 01:45 PM
mkguitar's Avatar
mkguitar
you may find that pushing a length of heat shrink tubing through, inserting the wire ends into the shrink, shrinking the tubing and pulling back through is easy.
no burrs on the bars, talcum powder for lube
mike
Old Dec 29, 2011 | 03:21 PM
BDHABT's Avatar
BDHABT
Cut off factory sheath,wrapped with electrical tape,lube with silicone grease.
I ran 2 pieces of mechanics wire down the right side.
Pulled the SE TBW thru first with first piece of mechanics wire,than pulled the other wires thru with 2nd wire.Went simplier than I had ever imagined.
Old Dec 29, 2011 | 04:19 PM
Mr HOG's Avatar
Mr HOG
I cut the original wire sheath off - to big and bulky IMO. Bought some long rolls of shrink wrap and did the entire length of wires. TBW and switch wires get wrapped separately of course. I ran the switch wires first then the TBW. You will need to get rid of the green TBW plug. It will not go past the bend in the bars easily. I tried but it would come unplugged every time i put any pressure on the wires. You can either order the SE TBW set-up or just cut the plug out and splice wires back together.
Old Dec 29, 2011 | 04:24 PM
Hoblick's Avatar
Hoblick
kept the sheathing on, taped the ends, used vasoline for lube
Old Dec 29, 2011 | 05:07 PM
blusmbl's Avatar
blusmbl
If I were to do mine again I'd buy the SE TBW kit. From what I understand it eliminates the green connector. I was able to get the green connector and the standard set of wires through the RH side but it took a decent amount of coaxing. It would've been a breeze if it wasn't in there. The left side practically fell through in comparison. I left the original sheathing on, and added heat shrink over the extensions, overlapping with the original sheathing.
CVO-RK
Feb 26, 2013 01:28 AM
berndog
Shovelhead
May 4, 2012 07:39 PM
Dyna2007
Dec 27, 2009 07:34 PM
BlackFLHR
May 19, 2009 03:10 PM
rgm
Feb 21, 2007 12:01 PM
