cracked sidewalls
Old Jan 3, 2012 | 05:04 PM
57red's Avatar
57red
Default cracked sidewalls
have an 11 SG i bought brand new in Aug, only have 7200 miles and the sidewalls have cracks in them already. I keep them properly inflated, I check at least 2 times a week when I check the fluids. Anybody else ever had this problem? They have 2011 stamped on the sidewall
Old Jan 3, 2012 | 05:35 PM
Imold's Avatar
Imold
Never on tires that new. Were they made in China? I've heard some bad things about Chinese tires. I've seen cracked sidewalls on good name brand tires with less than 1000 miles on them, recently installed too. But the code showed they were 10 years old.
Guys buying used bikes: don't go by when the tires were supposedly installed, check the code on the tire (google tire date code, you'll find it); you don't want to be riding a Harley with 10 year old tires, even with zero miles. Amazing how long some tires can sit on the back of a shelf, and then end up as a "special sale".
Old Jan 3, 2012 | 05:49 PM
57red's Avatar
57red
they both say made in usa, frnt just says 2011 rear has week 17 of 2011.
Old Jan 3, 2012 | 05:53 PM
JayStronghawk's Avatar
JayStronghawk
Have heard of this happening .. If they are the factory Dunlops should be able to get them replaced under warranty ..
Old Jan 3, 2012 | 05:56 PM
57red's Avatar
57red
they are factory, gonna take it in on Thursday.
Old Jan 3, 2012 | 06:05 PM
BMHARLEY's Avatar
BMHARLEY
Have 2010sg when it only had 3000mi.side walls started cracking,
took to dealer they replaced under war.
Old Jan 3, 2012 | 06:10 PM
Badfinger's Avatar
Badfinger
I've seen about half a dozen or so and only on 11 SG front tires.
Old Jan 3, 2012 | 06:35 PM
Bill10256's Avatar
Bill10256
It's been happening on the Road Glides too. Front tire only.
http://roadglide.org/showthread.php?t=8771
Old Jan 4, 2012 | 04:36 AM
103 sedona orange's Avatar
103 sedona orange
I had my front replaced at around 3,800 miles at no charge. I had cracks on both sides. There seems to be a problem with them.
Old Jan 4, 2012 | 05:30 AM
TUCCI's Avatar
TUCCI
Check the manufacture date on the tire, if it's less than 5yrs old I wouldn't worry about it, if they are 5yrs old replace them. The date code will have 4 numbers in a pill shaped circle. The first two digits is the month, the second set is the year ie: 1411 (14th week of 2011) or 0411 (4th week of 2011).
