Which HID kit??
Old Mar 16, 2012 | 08:19 PM
  #141
CHILLLS's Avatar
CHILLLS
Originally Posted by vscrl
I am trying to install the DDM Tuning H4 Hi/Lo Kit into my 2010 Street Glide and could use some reassurance.
First, it appears the kit I received is purposed for a dual headlight setup (like in a car). Can someone verify this for me please? Does it look correct in the picture (aside from the 3-prong connection which obviously connects to the bike harness).
Second, May I ignore the red battery terminal and black ground wire or are they necessary in this application? If they are necessary, there are red (capped) and black connectors inline with the bikes light harness, may I use those?
Please fill in the blanks for me. Thanks.
the extra black & red wire is for the hi/lo box. & yes it needs power to work or make the push/pull work on the bulb. not sure what ampridge the box requires but it might work off the extra wires you got under the fairing.
Old Mar 16, 2012 | 08:21 PM
  #142
vscrl's Avatar
vscrl
4th Gear
Originally Posted by bagman1
Man Im watching for your answers, I bought 3 kits one for my rg, strretglide, and an xr1200. They all have the same harness you do and no directions.
I'm pretty sure I'm on the right track with the connections, but the real question revolves around the power and ground wires. I'll be in good shape if I can connect those to the bikes headlight harness or not have to use them at all.
Old Mar 16, 2012 | 08:26 PM
  #143
bagman1's Avatar
bagman1
I have an 07 RG and I think that wire youre showing without having the schematic in front of me is power for a fender tip light in an EG. Everywhere I have read about HID lights the instructions say to wire to battery, others are saying they are using that wire, I would be worried about a draw that could overheat the wire/harness.
Old Mar 16, 2012 | 08:31 PM
  #144
vscrl's Avatar
vscrl
4th Gear
I wonder what the difference in draw would be between the HID and a fender tip bulb? I suppose it wouldn't be a big deal to run a new wire from the fuse in the HID to the battery. I could still use the black wire from the harness without concern, yes?
Old Mar 16, 2012 | 08:40 PM
  #145
CHILLLS's Avatar
CHILLLS
i would check to see what amp fuse is in the harness for the hi/lo box on the HID & see what size amp fuse is for the wire for the front fender.
Old Mar 16, 2012 | 09:03 PM
  #146
vscrl's Avatar
vscrl
4th Gear
Thumbs up
Good point. It's 25a in the HID harness.
Old Mar 16, 2012 | 09:09 PM
  #147
CHILLLS's Avatar
CHILLLS
OH BOY....you might want to run that wire directly to the battery. the fuel tank is easy to pull off just try to run it down a s much as you can.
Old Mar 16, 2012 | 09:13 PM
  #148
vscrl's Avatar
vscrl
4th Gear
Any idea why you wouldn't have had to do this, but now it's necessary to ground and power this?
Old Mar 16, 2012 | 09:18 PM
  #149
CHILLLS's Avatar
CHILLLS
the power & ground wires are just for the hi/low function. does not affect the light turning on.
Old Mar 17, 2012 | 11:30 PM
  #150
superprohero's Avatar
superprohero
Will these DDM kits fit in a Road King nacelle?
