Windshield Trimming
Old Jan 4, 2012 | 10:11 AM
Robert_W's Avatar
Robert_W
Question Windshield Trimming
Hay anyone trimmed a National Cycle VStream windshield with success? The standard height (14") is too tall and the low height (10.75") is too low. I don't like looking through the shield and I don't like the helmet buffeting I get with the shorter windshield. I also don't like the wind noise I get from the wind hitting the top of the helmet on long rides at highway speeds.
I like the VStream design because I get less fairing wobble from the other windshields I've tried.
Thanks in advance and ride safe,
Bob.
Old Jan 4, 2012 | 11:22 AM
mkguitar's Avatar
mkguitar
is this on a batwing fairing bike-?
if so, cut the bottom edge with a roto zip, use a 2nd windscreen as a template for the cut.
the cut edge is concealed.
open up the keyholes to make for easy swaps
I use a a number of different height seats and match windscreen height to seat, I like the top edge to "appear" to be 40' in front of the bike.
buffeting can be part of the helmet design- I have an H-D shorty with a "duckbill" at the back- it's the first stable helmet I've ever had
Mike
Old Jan 4, 2012 | 04:00 PM
JJHOG's Avatar
JJHOG
I have cut stock HD windshields before. Both RK and Batwing. I have made a paper template of the original top curve first. Then I take 3" blue masking tape and completely cover about 6 inches wide the area where I'm going to make my cut. I then tape the template onto the windshield and use a magic marker to transfer the curve onto the blue masking tape.
I use a handheld variable speed jig saw with a fine tooth blade to make my cut. You don't need alot of saw speed, just a steady hand. Let the blade cut the lexan and you just hold it steady with gentle forward pressure. Also, either clamp your windshield to a table or have someone help hold the windshield down and steady as you make your cut. After you're done take a fine grade piece of sandpaper in a sanding block and sand the top edge of the windshield to smooth out your cut and possibly correct and irregular cuts. Do not try to wrap around the edge too much. Maybe less than 2 degrees.
Old Jan 4, 2012 | 06:43 PM
Robert_W's Avatar
Robert_W
Mike
Hi Mike and thanks for the speedy reply,
I have a bat wing fairing with a faulty (fractures in the windshield) 10.75" VStream windshield I am exchanging for replacement under warranty. If I replace it with the 14" standard height I would like to trim it.
The base is not flat like my other windshields, so I cannot trim off the bottom. My concern is the crazy shape at the top of windshield. I considered using a band saw, but was concerned with the windshield bouncing on the saw table because of it's unique shape.
National Cycle suggested grinding away the top of the shield until I am happy with the height. Grinding 2" to 2 1/2" (or more) of Lexan is a lot of grinding. I was hoping for a more effective method. National Cycle does not custom trim their windshields.
Ride safe,
Bob.
Old Jan 4, 2012 | 08:08 PM
bohica48's Avatar
bohica48
this, I've done two this way with great success... The only thing I did different is i used 0000 steel wool to smooth the cut edge, just make sure you keep the painters tape on until your done.
TiRider
Sep 28, 2019 11:39 AM
geost
Feb 8, 2015 04:10 PM
see22ds
May 11, 2013 12:17 AM
Primo
Mar 14, 2006 12:41 AM
