Stock or Woods directional Lifters for 107 Build?
Thanks a million
The cam that I have now is a Tman 590 gear drive and it is very quiet for the cam it is. And all I have are stock lifters.
This method correctly aligns the oil feed hole in the lifter body with the oil feed channel in the lifter bore of the case. All other brands can be installed 90 to 180 degrees out of alignment.
Ř New Full Floating axle for the lifter roller race. This eliminates flat spots on the axle that can lead to failure.
Ř New Load Divider lifter bearing race designed to distribute an even load across the cam lobes. This feature reduces heat and stress that leads to increased cam and lifter life.
Ř A Newly designed push rod Lifter Cup that insures even, proper oil flow through the push rod to the top end.
Ř A Newly designed Lifter Body that allows piston jet oil port to remain open with cams up to .750 + lift.
Ř New hydraulic Piston Cup and Check Valve that increase bleed time rate. This corrective action gives you performance like a solid lifter but with ANTI-PUMP UP hydraulic operation.
