this re-mapping deal ? scam ?
I've been running my bikes the past 2 1/2 years with Stage 1 and xied's. Got 22K on my 2010 RK with no problem's what so ever. If you look at a map of the stock ECM, you will see the closed loop at 14.6 Expert's will tell you 14.6 is not too lean. If you look at the open loop section the FV's start at 13.8 and move into the 12's at higher throttle. Even Jamie published a dyno of the capability of the stock ECm. JMO
If you are running XIED's you are running a typr of fuel managment, just not a tunable kind. The XIED's richen your bike up to compensate for the more air your freer (than stock) breather is allowing in.
14.6:1 is not to lean, I will agree, but it is getting borderline to being to lean, especially on an air cooled motor like we all run.
As for the "tuner" you are referring to, I can't speak for him and what he has witnessed, I have never heard of stock o2 sensors adjusting 6% +or - 2. (not that it might not be true, I juts have never heard it). But look at it this way, if it is true, an open filiment (big sucker type) air cleaner will flow more than 6% more air than a stock filter. So even that logic doesn't hold water with me.
The OEM filter is not restrictive, it's just another HD conspiracy and scam, is that what you really wanted to hear?
Flame on, just suited up with my fire proof britches. Gotta warn you I'm fixin to start drinkin'. God bless America's military and their 4 day weekends, party on Wayne!
