Porting & Polishing Heads = More Power?
Old Jan 30, 2012 | 07:15 PM
Tek74's Avatar
Tek74
Default Porting & Polishing Heads = More Power?
I've heard that many riders have gone with a Stage 2 (Stage 1 + Cams), then decided they wanted more power, so they sprang for a Stage 3 (Ported & Polished Heads). Can somebody please elaborate on the details of this upgrade and how it equates to more power?
Old Jan 30, 2012 | 07:17 PM
krwould's Avatar
krwould
Here is an article for starters..http://www.floheadworks.com/Articles...ng_secrets.htm
Old Jan 30, 2012 | 08:28 PM
Clayslayer's Avatar
Clayslayer
Headwork reduces the amount or resistance for air entering an engine and exhaust leaving it. They simply flow more air than stock. More air means more oxygen/stroke. More oxygen means more fuel can be added, more bang, more power.
Anything that allows more air and fuel to be introduced to the cylinder for the combustion cycle will add power. Your engine is a glorified air pump, it sucks air in the filter, mixes with fuel, burns, then forces it out the exhaust. Any modification that will increase this airflow will increase overall power.
High flow air filters and intakes take care of the "air in" part. After the filter it enters the head, flows past the intake valve opened by the cam, is mixed with fuel, compressed and burned, then exits through the exhaust valve opened by the cam, and finally out the exhaust.
Old Jan 30, 2012 | 08:38 PM
FLTR2008TRIKE's Avatar
FLTR2008TRIKE
Beyond the heads you have to take into consideration the type riding your planning to do. A good engine builder will suggest the cams, exhaust and tuner to get the power your looking for.
Old Jan 30, 2012 | 09:26 PM
oasis03's Avatar
oasis03
Unless you plan to ride the living hell out of it or drag race you buddy, to me it was a waste of money.
Old Jan 30, 2012 | 11:44 PM
Tek74's Avatar
Tek74
Yeah.....I'm sorta just trying to figure out if its worth my while. I'm pretty much only into cruising, but additional passing power is always nice, both in street traffic and on the freeway. Especially when riding 2-up. But I'm thinking that upgrading my Stage 1 to a Stage 2 with some good cams will probably be enough for my needs.
Old Jan 31, 2012 | 01:02 AM
mkguitar's Avatar
mkguitar
How fast do you want to go?
How long do you want to do it?
How much do you want to spend?
You get to pick 2.
Reading up on headwork is interesting, what works for one motor or even application ( incl. laden weight, gearing etc.) may not work for another.
and head work ( as mentioned above) really needs to be thought out as part of a package with exhaust, cams etc.
It really is deeper into the science than many of us go.
One of the very interesting, counter-intuitive, discoveries has been that a rough wall on the intake tract will contribute to better flow than a smooth wall.
Mike
Old Jan 31, 2012 | 02:13 AM
hatchetman's Avatar
hatchetman
A rough wall on an intake will aid in beating the fuel molecules into smaller molecules which gives a more rapid burn.
Porting is designed to open the passage and allow faster entrance of fuel /air/ mixture into the chamber.
If the tech doing the mill work is not educated in porting, you are not going to get the benefit of better flow. Gotta look around for a shop with an awesome rep & the work isn't cheap.
A good set of cams & the proper exhaust is going to give you a huge boost in performance!
Hatch.
Old Jan 31, 2012 | 05:08 AM
mrfikser's Avatar
mrfikser
head work mostly only helps at higher rpms as at the lower rpms the engine already gets all the air it needs, so for cruising it does not help much, also you need to match the heads with a cam that "allows more air to enter at the higher rpms...since most normally ridden hd's don't spend alot of time in the high rpm range its mostly a waste of time...search around for cam profiles for engines with head work and you will see where the power is improved (mostly above the 3000-4000 rpm range)...
Old Jan 31, 2012 | 07:11 AM
1flhtk4me's Avatar
1flhtk4me
You get to pick 2.Mike
Yep engine work can get costly,especially if you pay someone to do it.
