2011 lowered Road King
Old Feb 17, 2012 | 07:22 AM
99%er's Avatar
99%er
Default 2011 lowered Road King
Hello all,
I have a few questions I am hopeful someone here can help with.
I recently bought a used 2011 Road King. After buying it and tinkering a bit, I noticed the shocks had been changed to Burley Brand. I assume this was done to lower the rear as these are shorter than the stock shocks.
My questions are:
1) How much lower from stock is the rear with these Burley Brand shocks?
2) I understand Burley Brand sells the rear shocks alone or as a 2 part kit to lower front AND back. I am unsure if the front was also lowered. How can I tell if the front has also been lowered. Is there a standard measurement to go by that I can check for with a tape measure or ruler? I cant ask the original owner because the bike was bought at auction.
3) I will be doing alot of 2 up riding. Will this lower profile be a problem?Should I return the bike back to the stock air shocks?
4) The bike is still under warranty. Will the suspension change void the HD warranty?
I genuinely appreciate any info / insights anyone here can provide.
Old Feb 17, 2012 | 07:34 AM
buggy's Avatar
buggy
If you measure from bottom of fork bell to center of axel its 13.5" on the front..The rear on my street glide the shocks are 12" and I added a 1" kit to get lower. I ride 2 up and the only issue is I hit my pipe at times pulling out where there may be a transition from a lot to the street. My pipe is also 4.5" round . my wife and I are 290 lbs total
Old Feb 17, 2012 | 08:29 AM
NDBadlands4-2's Avatar
NDBadlands4-2
I put lower shocks on my Ultra. I ride two up all the time and have never had an issue. As far as the warranty, did the dealer do the work? If yes, it should be covered. If not, it would have to be a rear shck related failure to void the warranty. So not much to worry about.
Old Feb 17, 2012 | 08:40 AM
99%er's Avatar
99%er
This site was highly recommended to me by a few friends / HD owners.
Now I see why.
Thanks !
Old Feb 17, 2012 | 09:13 AM
dbell66253's Avatar
dbell66253
If you do go back to the original height rear shock, I'd go with an after market brand or the HD premiums, the OEMs are not the best by far.
Old Feb 17, 2012 | 09:22 AM
TUCCI's Avatar
TUCCI
True, but changing the oil weight of the shocks 'could' be a fix that has given quit a few success. Its just a bit of a PITA, but by far do'able. Before I change out my stock shocks thats what I plan to do first.
Old Feb 17, 2012 | 10:48 AM
OldPhat's Avatar
OldPhat
If your front forks are stock and you need to lower it. Try H-D Part #46875-09 it is the
Road King lowering kit for your bike, that is if the rear shocks have already been lowered.
That being said, if you go lower in the front it is a good time to do chrome fork lowers at
the same time.
Old Feb 25, 2012 | 04:18 PM
baust55's Avatar
baust55
stock roadking air shocks are 13" eye to eye.
dandrumheller
Jun 17, 2016 07:15 AM
*Road King*
Feb 24, 2014 01:57 PM
rgolson
Touring Parts
Oct 27, 2012 01:59 PM
Biker90
Oct 4, 2011 02:23 PM
46and2
Apr 12, 2011 01:08 PM
