Yep, Another Monkey Bar???
Old Feb 18, 2012 | 10:08 AM
hdbagr's Avatar
hdbagr
Default Yep, Another Monkey Bar???
Was wondering if anyone has had any problem with 1" dia. ( grip,control area) Being to long? Installed left grip,controls and clutch perch and have a 1/2" gap between clutch perch and 1 1/4" bar section. Measured from the end of the bar to the 1 1/4" dia. The left side measures 7 1/2" and the right measures 7". ????
Old Feb 18, 2012 | 10:18 AM
rrcap2001's Avatar
rrcap2001
I didn't. Just cut off the extra half inch.
Old Feb 18, 2012 | 11:09 AM
Tee Bagger's Avatar
Tee Bagger
Not personally...but have read of others having this issue with yaffes bars. Solution, cut off the half inch.
Old Feb 18, 2012 | 12:11 PM
Nut08Ultra's Avatar
Nut08Ultra
Wow..that would tick me off and having to modify bars that cost that much in any way is BS. Q
Old Feb 18, 2012 | 12:20 PM
Mike's Avatar
Mike
Which grips are you using? I used PM grips on my 12" Monkey bars installation, no gaps.
Old Feb 18, 2012 | 12:59 PM
hdbagr's Avatar
hdbagr
I'm using PM grips also. I can cut them down, not a problem. Just was'nt expecting to have to "trim to fit" bars that cost that much.
Old Feb 18, 2012 | 01:12 PM
RNndER's Avatar
RNndER
I just completed a 14" set no problem using HD edge cut grips. I also have heard certain grips leave a gap with the PYO from other members.
Old Feb 18, 2012 | 04:15 PM
hog95023's Avatar
hog95023
I had a problem same as you with avon grips. The bars are made to harley grip specs and when I used the harley grips no problem. Check my threads that I started and you will see where I posted the photos when the shop installed the bars.
Old Feb 18, 2012 | 04:58 PM
LJROY's Avatar
LJROY
wow that sucks. if you cut it off then harley grips wont work or what?
ive seen pics on other threads and IMO it looks wrong with the gap..... just wrong.
i have a set of 12" MBB out in the shop to go on my ride when i get time. going to measure right know.
Old Feb 18, 2012 | 05:01 PM
hog95023's Avatar
hog95023
here the the bars with avon grips.
