P1238 and P1510 Codes after PYO Bagger Bars!!!
Old Apr 8, 2016 | 09:56 AM
ltomas's Avatar
ltomas
3rd Gear
Default wire diagram
thank you for all this help
this is diagram I did use to wire up the last time I did try to fix it
the only thing I can think of at this point is the TBW is a bad one??
just because it came new in box doesn't mean its a good one
but I will try one more time to look at the wires all over just in case I did mess something up
just don't see it I was so carful
even checked the voltage from yellow covered wires and black covered wires
don't remember at this point but
one side had 1.6 volts and when you twist throttle it goes up to 5 volts
the other for some reason starts at 5 volts and goes down from that point
I was thinking is it possible for these to be reversed ??
Old Apr 8, 2016 | 10:06 AM
SBates08's Avatar
SBates08
The voltages sound like the correct numbers. I'd go over everything again double checking molex connector making sure the pins, (or a single pin) isn't pushing out of place during connection. It's real easy to put a wire in the wrong place. I've done the same and looked at it 100 times and swore I had it right. Keep at it you'll figure it out. If you still have the stock TGS you could plug it up outside of the bars and see if it clears the codes when plugged in.
Old May 6, 2023 | 09:40 PM
Azer44's Avatar
Azer44
Stage I
Default Wiring Diagram
Originally Posted by Glen1978
FIXED!!! Thanks to the wiring diagrams in the shop manual......best money I ever spent right there. The #5 and #6 wires were swapped in the Molex connector. Swapped them around, cleared the codes and good as new.
Hey buddy, I am having the same issue. how can I get this wiring diagram? Can you share it with me?
chief1600
Aug 25, 2021 07:04 PM
SOCALHD
2014-2024 Touring Models
23
Mar 19, 2016 05:12 PM
Ahooosier
15
Jul 31, 2015 04:58 AM
motorcycleboy
May 27, 2014 02:59 PM
Freeway
Feb 9, 2012 10:57 PM
