kickstand worries
Old Feb 22, 2012 | 12:55 AM
  #41
DeJavu's Avatar
DeJavu
Wink
Originally Posted by PghCycle24
One quirk to the HD jiffy stands is that you can pop the spring off if you hit a curb/bump wrong. Just hppens sometimes. Our RK's and EG's have all had that vulnerability over the years. Just goes with the territory. Buy a spare jiffy stand spring (about $8) and carry it and a leatherman tool in your kit. Practice leaning your bike over (gently) with a friend and taking the spring off and putting back on, and then getting the bike back up on its wheels. It can be done solo, and without too much difficulty (gotta practice, though). Will save you grief if you ever pop it off when riding somewhere by yourself.
An easy way to install the jiffy return spring is to remove the retaining nut and pull the arm out of the pivot bracket. You can then easily remove/install the spring without any tension. Reinstall the arm in the bracket and tighten the nut.
If you don't have a jack or some way of blocking it up, a buddy holding the bike up straight works too.
Old Feb 22, 2012 | 01:22 AM
  #42
tinbender1966's Avatar
tinbender1966
I understand what you are saying. I felt the same way. I have a Ultra which is a 900 pound beast. Its does get a little scarey at frist. But after awhile you stop thinking about it.
Old Feb 22, 2012 | 05:08 AM
  #43
Ragtop's Avatar
Ragtop
I always push the bike forward to lock it in before I dismount. Every time, it's just a habit now.
Old Feb 22, 2012 | 09:21 AM
  #44
X Iron Butt's Avatar
X Iron Butt
I haven't done this but an old indy shop owner told me to remove the nut on top and the lock pawl and rotate the stand forward. Spring goes right on. Rotate back and replace pawl and nut. I don't see how you can remove the arm from the bracket without removing the spring first.
The locking pawl has an angle on the end so make sure the long side is to the rear. This makes it so when deploying the stand it stops when it is all the way forward and ready to lay the bike over on to it.
Old Feb 22, 2012 | 09:39 AM
  #45
103 sedona orange's Avatar
103 sedona orange
I "ALWAYS" look at the kickstand & make sure it slides all the way into the lock or whatever yuou call it.
Old Feb 22, 2012 | 10:05 AM
  #46
X Iron Butt
I always used to turn the fuel petcock to on before riding away
I always put the stand up before riding off.
I always put the stand down before leaning the bike over
I always put the bike in neutral before pushing the start button.
I always put my riding glasses on before riding off.
I always latch my tour pack latches before riding off.
I always used to turn the key switch to the off position.
With all of the always I did or do I have:
Replaced 3 coils and batteries from leaving the key in the on position (high dollar SUCKS).
Dropped the bike with the stand up.
Sounded like a cow going down the road because the kickstand was down and ringing on the pavement.
Took a few pucker seconds to decide my battery was not dead because it was in gear when I pushed the start button.
Had to go back home because my eyes were watering and my Ray Bans were on the workbench.
Latch the tour pack lid at speed because I heard it thumping on bumps on the interstate.
Pulled of the curb with a passenger and had the bike spit and die from no fuel. (many times until I got an extended fuel bowl and was in third gear before it ran out).
All because after 30 years of riding I always check these things.
Old Feb 22, 2012 | 10:59 AM
  #47
Very High Plain Drifter's Avatar
The newer bikes have a sensor that kills the engine if you click it into gear with the stand down. The dashboard looks very pretty with all the lights on!
Old Feb 22, 2012 | 11:21 AM
  #48
frog13's Avatar
frog13
Harleys???? My 2012 Street Glide runs just fine in first gear with the kickstand down ....... YES, even after almost 40 years of riding, I do make those little errors occasionally, but it does fold up just like it's supposed to.
Old Feb 22, 2012 | 11:29 AM
  #49
ElectraGlideSteve's Avatar
ElectraGlideSteve
I've never seen a Harley that shuts down when you put the jiffy stand down, even a new one.
Old Feb 22, 2012 | 11:31 AM
  #50
BlackPearl#1's Avatar
BlackPearl#1
This is a classic and you are not alone brother!!!!
Kris
