Changing fork oil
Old Feb 23, 2012 | 03:58 PM
jrbean1's Avatar
jrbean1
Default Changing fork oil
I was thinking about changing the fork oil in my 09 road glide. It has 49,000 on her. Was just wondering is it possible to change the oil with the forks still on the bike or the onlly way to change the oil is to remove them. I know to do it right you should change the seals but right now she is not leaking.
thanks for any input.
Jrbean
If its not broken mess with it untill you have something to fix.
Old Feb 23, 2012 | 04:09 PM
lonerider2's Avatar
lonerider2
Do a search on fork oil change, there's a post with photo's
Old Feb 23, 2012 | 04:27 PM
TUCCI's Avatar
TUCCI
Yeah you should be able to do it on the bike with it partially lifted on a lift.
Old Feb 23, 2012 | 05:26 PM
Classic Rider's Avatar
Classic Rider
You can (and should) do it. You will need an 1 3/8" wrench. I did it on my 08 ultra with 30K, what a difference!!! Give yourself plenty ot time to do this. Go SLOW on the refilling. Good luck
Old Feb 23, 2012 | 05:37 PM
RANGER73's Avatar
RANGER73
Put her up on a jack to take the pressure off the front. remove top bolts, then the screw on the bottom back side. Let drain. reinstall bottom screw, refill by the book, correct weight and correct amount. Reinstall top fork bolts. Lower jack and remove from under bike. Then go ride. It's the easiest thing to do on your Harley besides putting air in the tires.
Old Feb 23, 2012 | 05:52 PM
Eddie Haskell's Avatar
Eddie Haskell
The Axle wrench in the HD tool kit is the correct size, I didn't find that out until I was done changing mine
I did it a while ago on a different bike and I plan to do it on my new one before the warm weather comes. I can tell you this, it is one of those things you feel immediately and it is WELL worth the effort!!!
Old Feb 23, 2012 | 06:00 PM
HTNHARD's Avatar
HTNHARD
Replace the bottom screws with an allen head on or whatever else you choose. Those screws can be a pain to take out. Buy a funnel and some clear 1/2" tubing.
Old Feb 23, 2012 | 06:06 PM
Eddie Haskell
I bought a funnel with and on/off **** and measuring markings on the funnel , didn't buy it for this purpose but I'm thinking (hoping really) that it will be perfect for this application. I used an impact screwdriver to remove the screws, one of them tools you buy and then can't figure out how you ever survived without it.
Old Feb 23, 2012 | 07:28 PM
timberland's Avatar
timberland
From: Log home in SE Michigan full time. Log cabin in east TN, Smoky Mountians part time
I did a thread on this complete with photo's.....did the rear shocks too. search post started by me.
Old Feb 23, 2012 | 07:44 PM
don g's Avatar
don g
You'll be glad you changed it. I changed mine at 10,000 and it was really dirty. There's no need to lift the bike, just drain it, pump the shocks a few times and put the new oil in. I used the Sceamin Eagle fork oil and it helped stiffen the shocks and there's no more nose dive when using the front forks.
Joe Dirt 14
Dec 20, 2015 08:06 PM
Emdog
Jun 29, 2011 01:28 AM
Tinmanpope
Oct 26, 2010 02:00 AM
TMace
Dec 19, 2007 06:15 PM
joenuclear
Sep 10, 2007 05:46 PM
