Metal Slap
Old Feb 24, 2012 | 05:06 PM
gsbuickbrian's Avatar
gsbuickbrian
Stage III
Default Metal Slap
I have a new 2012 HD Ultra Limited. I just put 1000 miles on it and yesterday at idle if I crack the throttle open it sounds like metal slapping in the motor. Oil level is good, pressure seems ok, but along with this annoyance it has started to backfire a bit. I had Rienharts put on it and mapped with a less restrictive air kit....everything great until the 1000 mile mark. Any advise?
Old Feb 24, 2012 | 05:19 PM
brandss's Avatar
brandss
Wish I could help but I wouldn't fool around with it. Take it back to the dealer, assuming it was a dealer that did the download and have them look at it. She's way to young to have this issue. Good Luck. Keep us posted
Old Feb 24, 2012 | 05:24 PM
gsbuickbrian
Stage III
did and they sent me home....but I have to turn it in tomorow for 1000 mile check. They told me they would address it then. I just wanted my concerns note in case of a major problem.
Old Feb 24, 2012 | 05:30 PM
Glidedsternfan's Avatar
Glidedsternfan
Angry "They all make that noise!"
Or, even better yet, "It's supposed to make that noise!"
I hope they don't give you the run-around.
Good luck, keep us up to speed.
GSF
Old Feb 24, 2012 | 05:32 PM
BLKBAGGER's Avatar
BLKBAGGER
Maybe a heat shield? Could be any number of things.
Old Feb 24, 2012 | 06:16 PM
RHillbilly's Avatar
RHillbilly
I put the 107 kit in mine with the 777 cam after 100 miles it made that noise and got worse tore motor down found nothing thanks to jim at fuel moto it is a valve spring yours might be the same thing harleys valve spring pressures arent consistent
Old Feb 24, 2012 | 06:18 PM
EasternSP's Avatar
EasternSP
I had a noise develop in mine. Sounded like metal slapping when I snapped the throttle. Turned out to be a blown head gasket.
Old Feb 24, 2012 | 06:35 PM
TheGrandPoohBah's Avatar
TheGrandPoohBah
Get it to them, warranty work, stand your ground.
Not the time to be passive!
Old Feb 25, 2012 | 03:07 PM
gsbuickbrian
Stage III
Default Spark
They think it's spark related....in shop with the understanding not to return until problem is resolved. I hope they do not start to play games...I am too old for the run around.
Nitrusfix
Engine Mechanical Topics
11
Jul 4, 2015 09:53 AM
Harley Convert
Jun 18, 2015 10:14 AM
jkoch09ultra
Sep 10, 2006 05:32 AM
jerseyjeff62
May 5, 2006 09:33 PM
Stumpman
May 5, 2006 10:23 AM
