Hi,
Could someone please tell me the bolt (cotter pin) used in the rear (closest to casing) shift lever. The one that goes through the spline on the rod; the top of the lever then attaches to the bar which in-turn connects to the actual transmission shift.
It seems the head at least is smaller than the two 5/16 bolts that connect the heal and toe shifters?
Hi,
This is just a guess since you did not indicate the model or even the year.
1/4-20 x 7/8 hex head (grade 8)
