How to remove front fairing on a 2012 FLTRX
Old Mar 13, 2012 | 10:32 AM
jrobinson424's Avatar
jrobinson424
Default How to remove front fairing on a 2012 FLTRX
The Stealer is wanting to charge me an hours worth of labor to change out my speakers. I know it can't be that damned hard. How do you take the fairing off? It looks like all you have to is removed the bolts from the inner fairing. Gonna ask before I go to work on it.
Old Mar 13, 2012 | 10:37 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Buy a service manual.
DON'T do like ******** did in the video. COVER THE FENDER. AND TANK. If you don't, you WILL drop something.
http://www.youtube.com/watch?v=3SuzH2ToplM
Last edited by shooter5074; Mar 13, 2012 at 10:49 AM. Reason: I've fallen down, and can't get up
Old Mar 13, 2012 | 10:44 AM
Tailgunner1's Avatar
Tailgunner1
Buy a service manual. Best money you will spend....
Old Mar 13, 2012 | 10:58 AM
mllgator's Avatar
mllgator
Go to the step-by-step instructions by "wachuko".
Very clear instructions, good photos, excellent !!!
Printed them out and saved them to refer to another day.
Do it yourself. Between the instructions on the speakers and the link above it is no problem.
Old Mar 13, 2012 | 11:41 AM
XARAN's Avatar
XARAN
Don't pay the dealer for a simple job. Buy a manual or search for a thread here or on road glide.org there are Plenty of info. Easy job only Takes a tork screwdriver remove the headlamp and the inner fairing screws 10-15 minutes to remove. A little longer to install because of the gasket make sure you get it over the book on the top
Old Mar 13, 2012 | 11:55 AM
Akitakoi's Avatar
Akitakoi
3 Screws across the top under the windscreen, 2 screws on the sides near the forks and 2 more screws down below the speakers. Once it's loose reach in and pull the plug for the headlight. That's it.
Old Mar 13, 2012 | 12:05 PM
shooter5074
Wrong bike
Old Mar 13, 2012 | 12:06 PM
Iceman24's Avatar
Iceman24
I know Road Glide/SharkNose fairing is a tad different than a Street Glide, but believe what other riders are posting...not hard @ all & definitely no need to pay dealer for this project.
Get the $60 service manual now because this 1-project pays for it over 1-hr labor rate @ HD...
Old Mar 13, 2012 | 12:14 PM
jrobinson424
Thanks for the video Shooter. I can this myself. No Problem.
Old Mar 13, 2012 | 12:17 PM
shooter5074
Take your time...... COVER YOUR FENDER AND TANK. If you remove the headlights, it is easier to reassemble, and get the hooks lined up right. But if you are patient, it's not necessary. For me taking the headlights out vs not is a wash in the time it takes.
And don't over tighten the torx when you put it back together. They can strip out easily.
Grunt66
Feb 28, 2014 11:15 AM
Geezr Glidr
Dec 17, 2011 09:10 AM
kingddyd
Apr 18, 2008 07:17 PM
bucs012
Aug 18, 2006 10:25 AM
ElectraGlideinBlue
Mar 12, 2006 04:07 AM
