+1 on lacquer thinner or gasoline - comes right off. WD40 will do in a pinch also (it's the solvent in the spray).
BIG no-no on steel wool unless you really like the 'lot's of hairline scratches' look.
Steel wool is a newbie mistake, and belongs nowhere near a bike--- I've seen more finishes ruined by steel wool used on motors, wheels etc.
If you use a mechanical technique (such as scraping), you want a material harder than the tar, softer than the chrome.
I use a cloth and gas/lighter fluid as pointed out before.
plastic/nylon scraper ( incl. guitar picks) will also work if thick enough to get under it.
mike
Mike
I was waiting for someone to "nix" the steel wool idea .... NOT A GOOD CHOICE .... WD40 usually does a good job .... soak it a minute and it softens the tar .... also a good Chrome Cleaner followed by a Chrome polish will usually bring back the shine and luster to the chrome.
