Hidden antenna?
Old Mar 19, 2012 | 12:43 PM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
If the red light is on, and you have to plugged into the radio, it should work.
The lighter is just a convenient place to plug in the antenna power and ground.
Last edited by shooter5074; Mar 19, 2012 at 12:45 PM. Reason: Smile, your webcam is on
Old Mar 19, 2012 | 12:51 PM
FINALEFFORT's Avatar
FINALEFFORT
i give up then? i will take it apart tonight and make sure everything is pushed in all the way
Old Mar 19, 2012 | 01:18 PM
frog13's Avatar
frog13
Originally Posted by FINALEFFORT
i didnt not plug into the back of the cig lighter? that has to be my problem? but the red light it on??
Where did you connect the wires?
Old Mar 19, 2012 | 01:45 PM
FINALEFFORT
there was an empty hot plug and black ground plugged it straight into those
Old Mar 19, 2012 | 02:05 PM
frog13's Avatar
frog13
Did you meter test them to make sure they were hot? The antenna leads were designed so you could piggyback the lighter connections on them and then connect them to the cigarette lighter. Of course, they can connect anywhere, but you need to ensure the power is on at the connection point. From the description of your problem, it's all good, you just need power. I also recommend turning the radio on and making sure it all works before you button it all up. The other day I changed out my fairing speakers, had the right one done and tested it, then someone came over to talk to me while I was doing it. Simple job, right? Well, I installed the left one, buttoned up the fairing, went to go for a ride and only had sound out of the right speaker. DUH! When I was talking, I had hooked up the tweeter, but never connected the stereo outputs. Good thing that fairing removal is so easy .........
Old Mar 19, 2012 | 02:13 PM
nvsteve's Avatar
nvsteve
That's what I used. The two wires with connectors on them in the harness that
goes towards the headlight. It is switched and works fine with my $20 Metra.
Old Mar 19, 2012 | 02:27 PM
FINALEFFORT
NVsteve you switched it to the cig lighter and it worked fine?
Old Mar 20, 2012 | 06:37 PM
FINALEFFORT
After some looking the light was red saying it was getting power but some how the fuse blew, i only knew this cause today i noticed my turn signals were not working looked everything up all on the same circuit replaced the 15 amp fuse now i have radio!!!! thank you all for the help!!
Old Mar 20, 2012 | 08:23 PM
nvsteve's Avatar
nvsteve
No, I used the 2 unused wires in the harness.
Old Mar 20, 2012 | 08:51 PM
bgdv1's Avatar
bgdv1
had one and reception sucked. local station i listen to is only 35 miles away.
