transmission oil leak
Old Mar 20, 2012 | 04:03 PM
Keith50's Avatar
Keith50
Default transmission oil leak
Has the Sceliphron caementarium cause any of your transmission to leak oil?
Old Mar 20, 2012 | 04:07 PM
mkguitar's Avatar
mkguitar
( Mud dauber wasp)
Fairly common
signs can be seep at the clutch cable, or tranny fluid travelling up the clutch cable and seeping at adjuster.
Increased pressure can cause seep at the end cover ( "trap door") seal- torque spec for the end cover bolts is now 25 ft lbs.
also check the lower bolts which mount the exhaust
It was a year ago, Mazda had problems with spiders block fuel venting hoses:
http://articles.latimes.com/2011/mar...iders-20110305
Mike
Old Mar 20, 2012 | 04:09 PM
EastSideBikerTrash's Avatar
EastSideBikerTrash
...especially on days that end with Y.
bubdifab
11
Jun 4, 2024 06:33 PM
twistedcherokee
Oct 31, 2010 05:49 PM
bescaes
Oct 28, 2008 09:27 AM
FLSTF
Oct 17, 2008 08:58 AM
Unibomber
Aug 14, 2007 08:10 PM
