2008 road glide starting issues
Old Mar 28, 2012 | 09:37 PM
road glide o8's Avatar
road glide o8
well i took in shop tuesday...said if comprnsator...upgrade to SE...... got a call today...claiming compensator is fine....
said it is started clutch...they ordered one...may take a week to come in.... does that loud clanking and starter stopping sound like starter clutch or compensator ?
Old Mar 28, 2012 | 10:30 PM
Retrop's Avatar
Retrop
If you get the occassional clank, whiz, bang sound when do a hot start on late model bikes, try the following for an easy remedy: Crack the throttle ever so slightly as you crank the bike. It is usually a lean fuel situation that causes the bike to make this sound when it is hot. I know, I know, I can hear the laughing in the background already. Just try it next time you restart when the engine is hot. The SE compensator replacement does help because it is better engineered. Lots of people just relearn the starting procedure and that save money. You really don't care if your Harley dealers 4 kids get an Ivy League education, do you?
Old Mar 30, 2012 | 01:43 PM
road glide o8
wouldnt call it occasional... and not one clank or bang...several in row.... i have cracked the throttle..still bangs but does start and kind of reminds me of flooded start......but it real loud clanging or grinding..... and on almost all hot starts lately
Old Mar 30, 2012 | 01:48 PM
Pondskipper's Avatar
Pondskipper
Could easily be the starter clutch.
Old Apr 15, 2012 | 04:06 PM
JBourquin's Avatar
JBourquin
I started doing this last year, does help sometimes. Also I've found it doesn't happen as much if I crank it as soon as I turn the ignition on. If I let the fuel pump run and crank after it kicks off, it's twice as bad. Mine also sounds like the clang and grinding noises but to add to it sometimes sounds like it's backfiring through the intake. Just like the OP's, it seems to do it when it's hot/warm. First start of the day is usually fine, but it's all down hill from there. Almost sounds like the damn starters gonna smash something.
This is my first Harley so I thought it was just normal. I've messed with my maps for my PCIII with little effect. Any other ideas??
Old Apr 16, 2012 | 11:27 AM
road glide o8
that's sounds just what mine was doing...i took to shop few weeks ago....they replaced starter clutch under extended warranty....so far working fine
Old Apr 17, 2012 | 08:16 PM
JBourquin's Avatar
JBourquin
Took it to the dealer this afternoon. Luckily it did it right in front of the tech. He said it definitely needs a starter clutch. I explained to him how I've read a bunch of different places that claim it's a bad compensator that causes the clutch to go bad, he said it's a wear item and didn't think it was gonna be a problem, but he'd look into it. Bikes scheduled to go in for the work on the 30th. Luckily warranty will cover it all. I told him if the compensator did end up needing to be replaced I'd throw in the extra $100 to go with the SE upgrade. Guess I'll hafta wait and see.
Thanks again.
Old Apr 17, 2012 | 08:28 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
the weak stock compensated bottoms out and bangs>how many times will it do that b4 u beat the starter clutch to death?
Old Apr 17, 2012 | 08:41 PM
JBourquin's Avatar
JBourquin
Dealer told me 37k miles was pretty good for the original one. Apparently they don't usually last that long..
fxdx_ftw
Engine Mechanical Topics
36
Mar 10, 2015 11:40 AM
Ulflangkamp
Jul 4, 2012 11:43 AM
dochawken
Electrical/Lighting/Alarm
Nov 23, 2011 09:20 AM
DinoVelvet
Jan 2, 2011 10:38 AM
arizonapete
21
Jul 27, 2006 10:39 AM
