Sputtering, engine light on
Old Mar 22, 2012 | 12:13 PM
bigred292's Avatar
bigred292
Default Sputtering, engine light on
On way to work today my RK was acting up- bike seemed to be farting when I twisted the throttle- after a while of this the engine light came on. Light would go off when I let up on throttle.
We had a mild winter so I've been running it frequently. I did just put gas in it yesterday.
I'm at work right now and don't have a huge array of tools- any ideas or suggestions?
I was planning on disconnecting the battery and trying to reset it.
Any help would be appeciated.
Old Mar 22, 2012 | 12:17 PM
carlgrover's Avatar
carlgrover
Don't disconnect the battery. Get the fault code and see which one it is. There is a procedure in the service manual that describes how to do it. On my EVO, you have to turn the ignition switch on and off twice, back to on, then count the number of times the light blinks so see which code it is. You then look that up in a table and it tells you what's wrong with it. Pretty easy.
Old Mar 22, 2012 | 03:17 PM
bigred292's Avatar
bigred292
Thanks for the tip- I came up with codes 24 and 25.
If anyone could help I'd really appreciate it.
I want to know if it's OK to drive it home at least- 25 min ride.
Old Mar 23, 2012 | 12:16 PM
dbinbc's Avatar
dbinbc
Very good chance it was the gas you just put in. Bad gas can be a nightmare.
Old Mar 23, 2012 | 12:30 PM
69cj's Avatar
69cj
In the 2007 touring manual there are no such codes as 24 or 25. Should be a P0*** type number such as a P0562 is low battery voltage.
gilmour68
Aug 30, 2012 09:06 PM
nicko99
Aug 9, 2011 07:28 PM
pbalcer
Jun 7, 2011 05:43 PM
dturner
Sep 20, 2009 04:51 PM
Koppster
Sep 18, 2008 03:45 AM
