I've had mine for 2 years now and noticed right from the start my oil temps dropped from 210 to 180 on my dash gauge. I like the fact i can clean it over a paper plate and see everything that comes out of it as well as what's stuck to the magnet.
Wow, a 30 degree drop? I'm almost sold already! Thanks!
Ive read on here somewhere that the filter is rated at 35 micron. Regular Harley filters are 10 and the hd premiums are 5 micron. It seems to make sense that its higher flowing because of the less filtration compared to oem filters. For race applications where your constantly changing the filter I would use it. For my road bike I'll stick with the better filtration that the hd filters provide
If you ever have the time to do research about the way a paper filter and a stainless steel is rated you would understand that they are rated differently. Paper is rated at an average and ss at a absolute micron rating. Also know that the paper filter will go into bypass much more than a ss and this will allow unfiltered oil to pass. I had the same opinion before doing a great deal of reading on this subject.
The one post I would like to hear more about is the heat temps comimg down..................it would be worth it if this is true........we ride in 100+ in the summer and in town these bike are always hot............any more input?
I rUn a similar type filter and have for the last 4 yrs.I like the idea of cleaning and seeing what is in there.As far as lowered oil temps,I hav"nt noticed any difference but I run an oil cooler.
I have been using mine since 2008. I have 3 media inserts 2 spares and one in use all the time. I love the reusable filter the ease of cleaning it with some koresene followed with soapy water washing and rinsing then setting in on the self to dry until I use it again.
The other plus is the magnet that is on the filter insert gives you a visual to how your ferrous metal engine parts are wearing by the amount of metal sludge you would see stuck to the magnet when removed. You cant see that with a paper type throw away filter.
I didnt see any noticeable temperature drop but I have a Oil Bud oil cooler that does its job very nicely
Has it been worth the added expense for the K&P filter and extra media insert that I paid for 4 years ago....... Absolutely!!!
