outer fairing problem
Old Apr 2, 2012 | 07:15 PM
2swild's Avatar
2swild
Default outer fairing problem
I can't get the screw back into the brass fitting into the outer fairing...turns out it is stripped at the first few threads...i went to the local stealer today and got a new brass fitting...problem is, how do i get the old one out and how do i secure the new one in....perhaps use some glue...
Old Apr 2, 2012 | 07:24 PM
1pkraft's Avatar
1pkraft
I've not had that problem but I have talked to the service manager at my dealership about this in the past. He tells me this is a common problem and HD makes a repair kit for it.
I'd suggest asking them what's the best way to handle this.
Old Apr 2, 2012 | 07:39 PM
Shortbus captain's Avatar
Shortbus captain
Stage IV
I would get a tap and clean up the threads very carefully
Old Apr 2, 2012 | 07:59 PM
hog-doc's Avatar
hog-doc
Yep, first step after screwing up any thread is to get out the tap and die set!
bubbas1's Avatar
bubbas1
To put the new insert in just put the screw in the insert all the way and screw it in. The slotted end is what cuts its way in. Just make sure it goes in straight.
Old Apr 2, 2012 | 08:10 PM
soulpony's Avatar
soulpony
Ran into the same problem the last time I had the outter fairing off, as others have said, retap the threads, 1/4 x 20 as I recall.
Old Apr 2, 2012 | 08:14 PM
bubbas1's Avatar
bubbas1
Once you get new threads in the old insert, put one washer on the screw so the head won't pull thru. Add more washers that are big enough so the old insert will fit thru the washer hole but won't skip over the first washer. Put enough washers on so only a few threads catch and then start turning the screw in. The insert will pull out. I've done 3 like this with no problems.
customsoftail200
Aug 23, 2021 12:18 PM
$tonecold
May 11, 2014 09:33 PM
OldSarge
Oct 26, 2013 10:36 PM
ezglider
Aug 29, 2013 06:12 PM
Wally
Sep 27, 2009 08:25 PM
