ohlins vs progressive
Old Apr 9, 2012 | 12:13 PM
  #61
grbrown's Avatar
grbrown
Separation of oil and gas is one feature of the #3, but I believe that the damper design and components are also different than #2. Those features enable a #3 with 3" travel to out perform a #2 with 4" travel, which is another way of saying what I set out to write!
Old Apr 9, 2012 | 01:35 PM
  #62
jwd98056's Avatar
jwd98056
Originally Posted by hog95023
What did you guys do with the air lines? Leave them on by taping or zip tie or completly remove the system?
I don't think anyone responded to your question but I might have missed it.
The short answer is I would remove the system.
On my '12 RGU the air lines go to the two shocks and to the air valve that is mounted on a bracket that is on a fender mounting bolt on the left rear fender rail . The shocks have slip in air fittings so I didn't even need a tool to remove the air lines from the shocks. To remove the air line system after the shocks are removed just required removing and reinstalling one fender mounting bolt. On my RGU there wasn't any other hardware associated with the air lines. I just pulled on the air line from the air valve side and the air line for the right shock came right out. I suppose the air line could get hung up on something. If that happens the saddle might need to be removed.
I don't know how different other models and years might be but it can't be significantly more complicated.
Old Apr 9, 2012 | 02:49 PM
  #63
hog95023's Avatar
hog95023
Thanks jwd
Old Apr 9, 2012 | 02:57 PM
  #64
XARAN's Avatar
XARAN
Originally Posted by BlueKite
Interesting thread, but let's be absolutely clear about this. It is outrageous that hd is selling a 20 grand plus touring bike with crap suspension.
When are the customer base going to speak out?
I think that the vast majority of HD owners are completely satisfied with the stock suspension setup. I know that at HOG meets etc I see at least 7 out of 10 bikes running stock suspension. 2 of the sales men at my local dealer have been riding for 15+ years 40,000 miles + a year and run stock stuff. When I asked questions about replacement shocks they asked why?
Bottom line the stock HD air shocks are marginal at best for handling but they work very well as an easy shock to adjust for varying loads and that is what they are put on for. That is all any air shock is good at doing , either adjust for a different load or to raise or lower a vehicle to compensate for weights. Thats why air is often used in heavy applications, trucks, motor homes , heavy equipment
I think you see a lot more discussion on the forums about a lot of the mods we do because usually the people on forums are a little more passionate
Old Apr 9, 2012 | 03:56 PM
  #65
grbrown's Avatar
grbrown
Thumbs up
Xaran, you're right, that the majority of Harley riders are happily riding around completely unaware that we here in HDF and other forums are so anxious about this 'n that! Keeps some of us out of trouble.....
Old Apr 10, 2012 | 06:50 PM
  #66
shadowchaser's Avatar
shadowchaser
So many choices......
Old Apr 22, 2012 | 11:11 AM
  #67
Biker90's Avatar
Biker90
So after reading this and other threads, I was looking in to Ohlins 3.3 $ progressive 940.
I ended up getting the progressive 940 for 2 reasons.
1) is the $$$ difference, got a slightly used set on eBay for $365.00 shipped. And 2) the reason I originally took off the stock shocks on my EG and replaced with a 12 inch SG shock was cause I couldn't properly reach the ground (I'm 5.7 28 inseam)so the 940 gives me that added comfort of being 12 inches with 13 inches of travel.
Old Apr 22, 2012 | 03:10 PM
  #68
GJacobsJr's Avatar
GJacobsJr
Stage III
Have an 08 Street Glide, I'm 6'3" 215lbs., put in Progressive 940 Ultra Touring and the Progressive Monotube up front. What a difference, unbelievable ride, no more bottoming out up front. Easy to install as well. Well worth the price
Old Apr 22, 2012 | 05:15 PM
  #69
shadowchaser
Thanks for the dialogue, I have a set of #3's on the way!
Old Apr 22, 2012 | 08:32 PM
  #70
hog95023's Avatar
hog95023
I hope they work for ya.
