Well I have had my RK less than 2 weeks and this air shock thing is new to me. But I have already learned that you might just as well go out and buy the H-D $50 hand pump with bleeder and gauge. I tried several different pumps I had from bicycle to electric (paying attention not to over pressure). Nothing worked. I tried a regulated pancake compressor I have with a standard tire chuck. It worked but the act of checking the pressure afterwards changed the pressure by 5-10 pounds. The very small system volume and the need to shut off the air instantly make the H-D pump a necessity. I brought one home yesterday and it makes the job really easy.
I set my pressure at 35 pounds in anticipation of wifey riding with me. I probably should bleed that down because I solo more frequently and now pressure adjustments are easy!!
Depends on the year. I run 28 solo on my street glide.
I also run 28 in my 11 SG
Originally Posted by Biker90
My bike is a 11, I got the shocks off this furom but I don't remember from whom. Is there anywhere on the shock that will show me if the newer or older?
Maybe 28 or 30 would be a good starting point since you have a tour pack also, depends how much you weigh, I'm about 225.
I mareading from the 12 sg manual:
flhx
solo
up to 150 lbs 0
150 - 200 0 - 10
200 - 250 10 - 20
250 - 300 20 - 30
300 max load 30 - 50
Figure weight of entire load, rider, passenger, and cargo.
Jim
Should be a model or part # on them then check with the stealer for application
