...it seems people are always saying you don't have to down shift as often with cams, but I like bangin through the gears and with my 103 with my bassani road rage 2/1 se air cleaner and the power vision I have no problem passing trucks or any cars on these crazy highways in California.
With the right cams you would just be able to pass the trucks and cars faster. With the cams I have there is no less downshifting needed compared to stock, but you just have more to work with. OTOH, the wrong cam applied to a given setup may force you downshift more.
It's just I read all these threads about how you need cams to keep up with the pack and how much better your bike will be with them it's hard to ignore that.
I would agree with the last point, but as for keeping up with the pack I think that depends on how aggressive your pack rides. I rarely give my bike more than half-throttle when riding with others or when out by myself, but if you ride with a bunch of sport bikers you may want to have more.
Right on thanks for all the advice........ I do like to ride fast when she's not on it but thats very rare like I said just a little more umph not a dragster!
The stock cams are called "smog cams" for good reason. The complete lack of overlap in the stock cams helps keep emissions down by making sure no unburned fuel escapes with the exhaust gasses. Unfortunately, it also severely restricts scavenging, and the ultra short duration limits power production.
Over the last several years, the moco has done a bunch of work for us. In 06, the heads were redesigned to flow better, and beehive springs allow for more cam lift. In 07, the stroker crank became standard, and in 2012, the big bore upgrade was made standard for almost all big twins. About all you have to do now is add a decent exhaust, cams and get a tune to have a great running bike.
A stage II 103 is an exceptionally good motor, really all most of us will ever need.
