Antenna Caps?
Old Apr 21, 2012 | 04:41 PM
vabeachcop's Avatar
vabeachcop
Stage II
Default Antenna Caps?
Anyone know where I can get caps for the two antenna screws on an Electra Glide? I am switching to the hidden antenna inside the fairing.
Old Apr 21, 2012 | 04:52 PM
silverbullitt's Avatar
silverbullitt
I just used two vaccum caps. Go to an auto parts or hardware store. Cheap fix.
Old Apr 21, 2012 | 05:21 PM
vabeachcop's Avatar
vabeachcop
Stage II
Default Thanks
Thanks a bunch.
Old Apr 21, 2012 | 10:08 PM
greendragon52's Avatar
greendragon52
went to Home Depot and bought a split metal tube, which makes it a bit easier to widen it to slip over the antenna stud, cut it down to length and then topped it off with an acorn nut. Spray painted the pieces black. Just checked mine, and I'm pretty sure that the acorn cap is a 6mm. You could also bring the antenna with you to Home Depot and check the sizing at the store, they have sample bolts that you can fit the antenna onto to go the correct size.
Old Mar 10, 2013 | 08:27 PM
Deano13flhtk's Avatar
Deano13flhtk
Default Antenna caps
You can buy antenna screw caps at eglide goodies.
harleyman1340
Dec 4, 2019 09:39 AM
BigDogIdaho
Audio Systems
Apr 22, 2019 09:53 AM
DeneFXDWG
Audio Systems
Sep 3, 2015 07:20 AM
hawg50
Nov 20, 2012 09:07 PM
BLACK AVENGER
Mar 28, 2006 06:41 PM
