Seats & Consoles.........
Old Apr 21, 2012 | 05:42 PM
GLACIERPEARL's Avatar
GLACIERPEARL
Default Seats & Consoles.........
Hi All,
I have an '06 Ultra.
It has the 'shorty' console, with the CB hookup, etc.
Today,....I found that the plastic 'base' of my seat is cracked where the metal tongue is attached in the front, ( that goes in the frame ).
My question is: Can I replace my seat with a 'shorter' length seat, that doesn't run so far up the tank ? Is the Street Glide seat shorter, with a longer dash panel on the fuel tank ??
I wanna get rid of the HIDEOUS Ultra tank console anyways.
So,...........if I find a Street Glide seat and console,................will it bolt right up ??
I'm sure the seat would be easier to find used,...........but there are many companies that make a nice chrome console.
Any ideas for either ??? THANKS !!
~GP
Old Apr 21, 2012 | 08:06 PM
Harleypingman's Avatar
Harleypingman
Jay, a console from an '06 or '07 SG will be a direct replacement; HD also sells an identical piece with a different stick-on insert than the SG uses--it's what I put on my bike.
Likewise, any '06 or '07 seat will fit as a direct replacement.
Carl
PS: I was going to mention that you could relocate the rider headset connector in your OEM console, but recall that you swapped out the HK head unit/CB, so the connector is a non-issue for you.
Old Apr 22, 2012 | 12:34 PM
GLACIERPEARL
I'll keep an eye on the classifieds for an OEM Streetglide seat & tank console !!
Old Apr 25, 2012 | 02:50 PM
pit1600's Avatar
pit1600
i swap mine for HD cvo's like console. I use it with SG seat or my Ultra seat. It make the tank's look more clean.
Old Apr 25, 2012 | 03:14 PM
mikelikesbikes's Avatar
mikelikesbikes
Can't help ya with the console but as far as the seat, anything 97 to 07 will work. Check the classifieds here and ya might find just what you are looking for.
Old Apr 25, 2012 | 04:55 PM
GLACIERPEARL
Doesn't the Ultra seat go way farther up the tank than the StreetGlide seat ??? That's what I want ..............a way shorter run up the fuel tank/longer console.
Old Apr 25, 2012 | 09:23 PM
BackRoader's Avatar
BackRoader
Yes, SG and RK seats are the same. short run up the tank. They also make a chrome filler piece for the dash if you choose to stay with your EG dash.
Old Apr 27, 2012 | 02:51 PM
pit1600's Avatar
pit1600
yes the Ultra seat goes farther up on the console. The console is more longer than oem one and goes to the end of the tank, under the seat nose. It looks good with both seats
Old Apr 27, 2012 | 04:51 PM
GLACIERPEARL
I want a longer dash.........hate the looks of the shorty.
DieselJoe
Feb 14, 2016 04:44 PM
wrenchguy24
Oct 30, 2011 09:28 PM
KSGLIDEGUY
Feb 14, 2011 08:37 PM
floridian46
Nov 22, 2007 05:45 PM
twohats
Jun 4, 2006 10:51 AM
