"USA Catalyst" on pipes
Old Apr 26, 2012 | 06:46 AM
motorrader's Avatar
motorrader
Default "USA Catalyst" on pipes
What does "USA Catalyst" stamped on one of the exhaust pipes mean? I purchased a set of headers and exhaust pipes for my 03 RK and was informed that they do not have a catalytic converter. But I noticed the USA Catalyst stamp.
Old Apr 26, 2012 | 06:58 AM
smitty901's Avatar
smitty901
2003 only CA models had CATs in them it appears you have a CA.
Set of pipes.
Latter HD moved them to the headers a much better place to put them.
Old Apr 26, 2012 | 07:45 AM
Pumba11's Avatar
Pumba11
I had a set of '06 catalyst mufflers. If you looked into the inlet end of the muffler with a flashlight you could see the gray honeycome catalytist material.
Just an FYI I was also able to core it out.
Old Apr 26, 2012 | 10:15 AM
motorrader's Avatar
motorrader
I can see the catalyst honeycomb material, but is that the same as a catalytic converter? The seller assured me that the pipes do not have the catalytic converter, did I get screwed?
Old Apr 26, 2012 | 10:16 AM
boom23's Avatar
boom23
Originally Posted by motorrader
I can see the catalyst honeycomb material, but is that the same as a catalytic converter? The seller ausserd me that the pipes do not have the catalytic converter, did I get screwed?
That's how the catalytic converter looks...
Old Apr 26, 2012 | 10:17 AM
motorrader's Avatar
motorrader
I see the catalyst/honeycomb material which appears more like a metal baffle in the pipe, but is that the same as a catalytic converter? The seller assured me that the pipes do not have a catalytic converter. Did I get screwed?
Opps, sorry, didn't realize the first post (post #4) went through.
Old Apr 26, 2012 | 10:52 AM
Romingnometx's Avatar
Romingnometx
That honey comb is the catalytic converter. So yea, you got a set with them.
Old Apr 26, 2012 | 12:14 PM
Pumba11's Avatar
Pumba11
You don't have a converter in the head pipes...but you do in the mufflers. Bummer.
Old Apr 26, 2012 | 04:59 PM
motorrader's Avatar
motorrader
Looking into the pipes where the head pipes connect, the exhaust pipe stamped USA Catalyst has the gray honeycomb material, but the other pipe doesn't. What does that mean?
Thank you all for your info.
Old Apr 26, 2012 | 05:10 PM
mtclassic's Avatar
mtclassic
it means one has a catalyst and one does not. I believe that is how they did it when the first started using cats in calif.
