A/C backplate?
Old Jan 2, 2007 | 09:12 PM
Abnmarine's Avatar
Abnmarine
Default A/C backplate?
I bought my bike with the SE A/C. I was under the impression that is had the complete assembly and not just the filter. I'm thinking it is just the SE filter. Here is a pic:
I want to upgrade the filter setup to the K&N 320cfm. What else should I change?
Old Jan 2, 2007 | 09:16 PM
swomack's Avatar
swomack
Default RE: A/C backplate?
Thats the assembly. The orignal covers the entire back of the cover.
Old Jan 2, 2007 | 09:17 PM
52edub's Avatar
52edub
You got everything. The old air cleaner was a large piece of black plastic. What you have is a simple back plate and an ok filter. They use to be cleanable, but then HD went to paper.
Old Jan 2, 2007 | 09:23 PM
maineultraclassic's Avatar
maineultraclassic
You have the SE air cleaner kit, what you have a picture of is the SE backing plate.
If you want a 320 cfm air cleaner, check out the Zippers upgrade filter for $62.
http://www.zippersperformance.com/ca...&prod=2155
That is the filter I have on my bike and it works great. You can still use the stock cover with it if you want.
Steve
Old Jan 2, 2007 | 09:50 PM
Abnmarine's Avatar
Abnmarine
Thanks guys. That sure makes me feel better. I guess I will just paint the outside of the plate black. I remember reading a post here where someone did this.
I'll order the 320 cfm filter from Zippers and call it a day.
Old Jan 2, 2007 | 10:44 PM
smknflms's Avatar
smknflms
..HD has chrome SE backing plate for 40 bucks...5 minute swap-out.
Later
Old Jan 2, 2007 | 10:48 PM
Abnmarine's Avatar
Abnmarine
I thought about that but black is fine with me. I already have enough chrome and the plate isn't seen much.
ORIGINAL: smknflms
Later
Old Jan 2, 2007 | 11:20 PM
gman's Avatar
gman
might also check out the V&H chrome back plate assy.
[IMG]local://upfiles/12616/F904B8436F3E4F548B2909F86E6F3816.jpg[/IMG]
Old Jan 3, 2007 | 10:23 AM
Hardly Dangerous's Avatar
Hardly Dangerous
ORIGINAL: Abnmarine
ORIGINAL: smknflms
Later
I'm doing mine black this winter also. Make sure you do high temp paint.
Old Jan 3, 2007 | 01:08 PM
Neil's Avatar
Neil
Thought I saw a black backing plate offered by HD. Same surface as the blacked out stuff on a Night Train - wrinkle black I think it is called. It is just a replacement for the one you have now.
Neil
