2009 ABS: Visual ID and Question?
Old May 4, 2012 | 05:47 PM
03psd's Avatar
03psd
Default 2009 ABS: Visual ID and Question?
Goint tomorrow to look at several 2009 FLHPi bikes. Several are supposed to have the ABS option while others do not. What visual differences can I find to determine which have ABS and which dont? I believe in some model year the "brain" was in the bag but I was told that it has been relocated in newer years to allow for full use on the bags. Also what value would you place on an ABS bike over a non ABS bike as far as price. $500 more ? Lastly, do all late model bikes have the Brembo brakes wether they also have ABS or not?
Old May 4, 2012 | 05:52 PM
2black1s's Avatar
2black1s
Easiest way to quickly determine if a bike has ABS is to look at either the front or rear wheel and find the wheel speed sensor and wire.
Old May 4, 2012 | 05:53 PM
dawg's Avatar
dawg
All 08 and later touring have Brembo's regardless of ABS or not.
Old May 4, 2012 | 05:56 PM
03psd's Avatar
03psd
got a pic of what I am looking for by chance??
Old May 4, 2012 | 06:06 PM
dawg's Avatar
dawg
Left side, front wheel, instead of a wheel spacer there will be a black sensor with a wire coming off and going up into the fairing. See red arrow in picture
mkguitar's Avatar
mkguitar
on the right side of the frame neck ( rt as you sit on it, just in front of tank)- will be 2 brake hoses on an ABS bike.
just under the wiring harness wrapped in a black plastic sleeve.
abs is very, very good.
Mike
Old May 4, 2012 | 07:35 PM
lionsm13's Avatar
lionsm13
The Brembo's work good too.. even w/out ABS.
Best brakes I've ever had.
Old May 4, 2012 | 08:19 PM
speedwaysteve's Avatar
speedwaysteve
Turn the ingnition on if the bike has abs the abs light on the dash will blink. It goes out when the bike moves foward
Old May 4, 2012 | 08:28 PM
skratch's Avatar
skratch
in addition, there will be a second black wire that is zip tied to the left brake line coming off of that spacer dawg pointed out. you should be able to see that a mile away.
Old May 4, 2012 | 08:30 PM
speedwaysteve
Theres also a small tag on the caliper that says abs
