Ohlins Cool-aid?
Old May 16, 2012 | 08:58 AM
shooter5074's Avatar
shooter5074
From: Western Illinois, land of bad roads, and corrupt politicians
Thumbs up Ohlins Cool-aid?
Last night I installed my Ohlins 2~2a shocks that Howard at Motorcycle Metal built for me.
He built them for 70/30 with my 190 lbs and some extra to compensate for filling the saddlebags and packing for trips. He also used the shorter springs, which seem to work VERY well
Setup was a snap. I had read all of the directions before even ordering them, so I knew what to expect. Talked to Howard about the install, and all was good.
For Howard: Sometimes it's good to be a LITTLE PATIENT
So far I have a whopping 35 miles on them ..... a storm came up just as I was going for my test ride last night. But I did get some miles in.
The first thing I noticed was, I didn't bottom out at the end of my driveway. And I didn't feel like the bike was going to fall apart on railroad crossings.
The shocks are firm, without being harsh like the stockers were. I can still "feel" the road. That's a good thing. A floating Cadillac ride is NOT a good thing if you want control.
So with all that said..... I will add to this when I get some hard miles on them.
But so far, they are worlds better than the stock shocks. Handling is improved, as well as comfort.
Old May 16, 2012 | 09:01 AM
Lowcountry Joe's Avatar
Lowcountry Joe
Good report. Make sure that pre-load is set correctly and it will make all of the difference in the world.
Old May 16, 2012 | 09:04 AM
grbrown's Avatar
grbrown
Welcome aboard! They will ease up over the next few hundred miles and get even better.
Old May 16, 2012 | 09:14 AM
tj316's Avatar
tj316
after break in they will be even better , please do follow up , I am running the #3-#3's but the the #2-#2a's would have been my next choice and I like the positive feedback they keep getting
Old May 16, 2012 | 09:22 AM
shooter5074
The 2~2a shocks had the length, and stroke that I wanted. Sitting on the sidestand, they are pretty much stock height. When I sit on the bike and the sag hits, they are slightly shorter than stock. That's what I was going for. I get the short stance but more stroke than the stock 2 X 4 boards that Harley calls shocks.
That's what I keep hearing..... even if they don't get better, I'm one happy camper.
There is ONE drawback that I have noticed.......... makes me realize how crappy the stock front end is.
Old May 16, 2012 | 10:46 AM
fabrik8r's Avatar
fabrik8r
Get your shocks broke in and dialed in first, then do the front, its easier to tweak one end at a time to get started, then after you get them both close you can work to synch the front and rear. The modified Intiminators are really good solution to the front that won't break the bank.
Old May 16, 2012 | 10:54 AM
jackloganbill's Avatar
jackloganbill
Wish I could afford them!!! But from an engineering point of view, placing the bottom shock mount aft of the axle is just wrong. The shock travel and action would improve by moving the mount three-four inches forward. Just saying....
Harley does a few things that are just plain dumb. This being one. The top triple clamp on FLHs being another. For a few bucks they could make some huge improvements. Such as updating the FLH frame in '09. Small change that made a huge improvement in handling.
JackL
Old May 16, 2012 | 11:36 AM
qtrracer's Avatar
qtrracer
JackL
Explain why you think the location is wrong. Wheel travel would increase yes but the leverage would increase(shock speed is slowed) over the shock as the axle travel nears the point of the shocks bottoming out which is exactly what you don't want. This creates less damping and a lower spring rate as the bike nears full travel increasing the chances of bottoming out. The leverage needs to be lessened(shock speed increased) as the wheel travels through its arc. Moving the lower shock mounting points closer to the swingarm pivot will have the opposite effect.
Old May 16, 2012 | 11:41 AM
grbrown's Avatar
grbrown
Wink
JackL
I beg to differ about the location of the rear shocks. Putting them as close as possible to the axle is the right thing to do, from an engineering point of view. Steals room from the bags, compared with the FLHs of yore where the shocks were too far forward.
However you are quite right about the top yoke/triple-tree. Howard of Motorcycle Metal is working on a solution!
Old May 16, 2012 | 11:54 AM
shooter5074
+1 Plus having it forward 3 or 4 inches, and more of an angle increases the chance of wheel hop...... which can be deadly on a sweeper.
More leverage means the shock is only making suggestions to the swingarm, instead of CONTROLLING it.
Having the shock out near the axle and more vertical also means the tire maintains contact with the pavement much better, and more evenly. As in ..... better control.
Do you want your shocks to react to a bump after your are already past it?
Last edited by shooter5074; May 16, 2012 at 12:06 PM. Reason: TinkerBell is a little hottie
