I just changed my windshield and mistakingly removed the windshield screws, I have the end two in however the center one will not align properly, any tips on getting the screws in, don't want to strip the the threads. Thanks.
I'd start with the center screw by just threading it enough so it won't fall out. Then align one of the sides and start threading it in but leave it loose - move on to the next one. Then alternately tighten all three.
Hey neighbor!! Funny you mention this as I just had my outer fairing off this evening!! Just barely tighten each one as you go - make sure each one is good, then tighten... Might need to give the fairing a nudge as you go!!
I always leave 'em all (7) loose until they're all in. And +1 on doing the center one 1st, then the outers, with the 4 bottoms still loose. Then, tighten all - gently.
I enlarge the 3 "keyholes" with a rotozip, to more of an inverted U shape.
that allows a slight loosening of the 3 screws and a quick swap.
the windscreen will just pull straight up and out
less wear and tear on the faring screws.
Mike
I'd be worried about the shield working its way loose and flying off at speed when enlarging the keyholes.
Even with the stock keyholes on my shield (National Cycle V-Stream) mine slides out of position from time to time and I have the screws tightened much tighter than I like them. I know I'm going to strip the insert out of the plastic one of these days, but I have no choice if I want the windshield to stay put.
