American Customs Header!
Old May 25, 2012 | 01:26 PM
goshivan's Avatar
goshivan
5th Gear
Default American Customs Header!
Has anyone used on of these? I have read on their website that you can use this and loose virtually all the heat from the right side and not have to use a tuner! I have a 2012 Ultra Limited and the heat is deffinetly an issue. Need some feed back please!
Old May 25, 2012 | 01:33 PM
DannyZ71's Avatar
DannyZ71
I have their slip-ons, which are basically Harley mufflers hollowed out and fitted with their own baffle system. Their head pipes are probably just Harley stock pipes with the cat removed. You can do the same thing if you can weld, or know someone that can.
I love their slip-ons. I found a slight leak where they slipped over the head pipes. Since fixing that issue, I've been able to run them without any baffles without the decel popping I was getting before. Sound great, even with the cat still in place in my head pipe.
Old May 25, 2012 | 01:52 PM
goshivan's Avatar
goshivan
5th Gear
They say that they install their stuff inside so their is no heat and you don't have to retune. For only $200 it sounds like too good of a deal to pass up!
Old May 25, 2012 | 01:57 PM
DannyZ71's Avatar
DannyZ71
I don't know what they would add to the pipes that would reduce the heat, other than an air conditioner. I still think all they do is remove the CAT. That will reduce the heat a bunch.
Old May 25, 2012 | 02:12 PM
jjpish's Avatar
jjpish
I have had their decatted headpipe on my 11 Ultra since last fall. Certainly reduces the heat and really helps the sound. As far as a tune, I did not retune until this week when I bought the Dynojet Power Vision. There is a noticeable difference but I could not or would not say that de-cattting the headpipe had any noticable negative effects. Unless you can cut and weld yourself it is a cheap alternative for removing the CAT.
Old May 25, 2012 | 03:09 PM
Pagan48's Avatar
Pagan48
Yes, they just decat the stock pipes. I bought a Wild Pig decated headpipe that is just like the ones from American Customs. It's $150.00 and you get $50 core refund if you send back your stock pipes. Definately cooled the bike down. Better sound and haven't noticed any difference in performance with my stock intake and mufflers.
Old May 25, 2012 | 03:11 PM
RK14SGS's Avatar
RK14SGS
Remove the cat and save money.
Old May 25, 2012 | 03:18 PM
TUCCI's Avatar
TUCCI
Yeah thats what I did, it took me all day on a Sat and $30 to a muffler shop. Then I took the tail pipes and cut the 4" small baffles out with an 1 1/2" hole cutter which I understand is what AC does except they weld a flange with two bolt threads as well as a flange on the original mini baffles. The pipes without the mini baffles sound like a car thats lost its tailpipe. My wife liked the sound but me, not so much. Its only a good setup to buy if you have no mechanical ability whatsoever, otherwise do it yourself and save all the $ for a nice set of slip-on mufflers.
JD#7
Exhaust System Topics
Jun 10, 2018 11:00 AM
paid4c4
Mar 7, 2015 05:59 AM
chgofirefighter
Jun 11, 2013 10:10 AM
The Reverend D
Oct 23, 2009 02:33 AM
06BlackFLHXI
Jun 8, 2007 10:05 AM
