Well I have read all kinds of threads with how to wire an additional relay into the starting system. I am not the sharpest knife in the drawer when it come to electrical. Does anyone have any kind of diagram showing how to do this. I have a 2000 RG with a107 higher compression, I do have compression releases on the heads. I have a new battery and new starter, but every once in while the dreaded click. I picked up a new relay today and will be putting that in tomorrow, also checking the connections as I go. I cracked a circuit breaker while doing this, so will go get one tomorrow as well. As mentioned, a diagram would sure help me out.
Also should I put a switch in line, so that I can turn off the headlight while starting the bike. I know that draws a lot of juice, it doesn't take long and the volts are down if I leave the bike ignition on and don't start the bike right away.
Thanks everyone.
a sharper knife could wire in a relay which would kill the lights for you when the starter is cranking- save that project for another time, but i thought I'd mention it.
it'll bypass the starter switch, relay and associated wiring.
as always make sure the battery cables are in good shape ( no "powder" coming out when you tap them on a table) and clean and tight connections at both ends.
