Intiminator and racetech springs preload help
Old Jun 5, 2012 | 11:44 PM
bikehe's Avatar
bikehe
Default Intiminator and racetech springs preload help
Hi, Ive got racetech 0.95 springs and ricor intiminators but I'm not sure how long to cut the tube spacer. The RT springs are 5 1/4" shorter than the OEM ones so could I cut the spacer tube 6 1/4" long, which would give me a 1" preload? Also what is the the correct sag for getting the front geometry correct as I cant find it in my service manual and is this measurement taken from the top of the fork slider to the bottom of the triple tree. Any help greatly appreciated as I'm really stuck on this one. Thanks
Old Jun 6, 2012 | 09:58 AM
keith t's Avatar
keith t
suscribed
Old Jun 6, 2012 | 10:43 AM
WARDSPARTSWERKS's Avatar
WARDSPARTSWERKS
There are several influencing factors that make setting the sag a trial and error task. No magic formula to get right 1st time around. 3" has proven to be a good start point for spacers. Your sag goal should be 1/3 total travel or 1 5/8" for a standard height touring bike.
Old Jun 6, 2012 | 11:00 AM
WetSider's Avatar
WetSider
Lots of excellent information contained in this thread.
https://www.hdforums.com/forum/touri...rk-better.html
Old Jun 6, 2012 | 01:25 PM
bikehe's Avatar
bikehe
Thanks WetSider have read that twice and your right about the excellent info. From what I've read, seems to be that on the EG I can cut the spacer between 5" and 5 1/2" which will get me started but either way looks like I'm going to have to drop the forks twice to get it correct for my weight. Question now is if running the intiminators they tend to ride higher is that correct, so is the 1/3 rider sag correct for most bikes from the info I get on that link.
Old Jun 6, 2012 | 02:47 PM
WetSider's Avatar
WetSider
I hope you're lucky and get it cut right on the first go-round.
Wish I could give you info that would be anything but speculation, as I don't have hands-on experience with doing this mod (even though it's on my list). One shortcut might be to PM fabrik8tr directly with your specific situation and question(s). Not sure how active he's been on the forum, as I believe he's launching a new biz(?) but I'd give it a try. Don't know others around here with more experience on this topic.
Old Jun 6, 2012 | 03:29 PM
bikehe's Avatar
bikehe
Thankyou Sir I appreciate all the info I can get as cant proceed any further until I know approxiamately where to cut the spacers and the instructions are very generic and after talking to the RT rep down here I was no closer to an answer. Best info I've read was cut the spacer to make the spacer and spring length same as OEM spring and add 1" preload and take wardsparks werks info and work on a 1/3 sag, so may do that, just not confident. Will pm fabrik8tr to see if he has enough data collected to put me in the ball park. Chances are we wont get it right first time but closer the better.
Old Jun 6, 2012 | 06:48 PM
uscanuck's Avatar
uscanuck
I used the same 0.95 RT springs and Ricor Intiminators on my 2010 FLHTK.
Stock springs were 473mm and RT were 343mm so difference was 130mm.
The washers used with the Intiminators are 5mm thick total so I cut the spacer 125mm (~5"). This gave me exactly 5/8" sag.
To get the 1 5/8" sag I basically cut another spacer 100mm (4") and then sag was exactly 1 5/8".
Racetech supplies enough spacer tube to cut these two times. If I were you I'd start closer to 4" than 5" or 6". If the 4ish" doesn't work you can cut the rest of the tube in half and still have 5+" spacers to play with.
Also, I'm 185lbs and that sag was with just me on the bike.
Old Jun 7, 2012 | 08:29 AM
keith t's Avatar
keith t
I am about to make the same mod, never done this before so I am wondering about how to determine the amount of fork oil to put back in. Would I just measure what I drain out prior to fork removal, that doesn't seem like it would be close enough since there would be oil in the tube and on the spring etc or do I not drain the fork and get the fork off and measure from the top of the tube to where the oil is, and if so do I need to replicate the pitch of the fork before I measure?
Hope this makes sense
Thanks to all
Old Jun 7, 2012 | 02:40 PM
bikehe's Avatar
bikehe
Thanks to all
You will have to drop your forks. To get the correct oil level I bought one of these. The correct level is 125mm from the top of the fork tube with the springs out, and the fork tube compressed.
http://www.handsontools.com/Motion-P...l_p_53847.html
