"chirping" noise on left side
Old Jun 7, 2012 | 10:06 AM
gomiller2's Avatar
gomiller2
Muffler mounts spray with lube every now and then good place to start anyway.
Old Jun 7, 2012 | 10:12 AM
bhm07's Avatar
bhm07
Make sure your belt tension is good too tight or too loose and it will chirp as well
Old Jun 7, 2012 | 11:07 AM
mkguitar's Avatar
mkguitar
+1
too loose a belt will chirp on deceleration, the outside of the belt will contact the inner primary above the front pulley, causing a chirp.
more common on lowered bikes.
mike
Old Jun 9, 2012 | 08:18 AM
byucop's Avatar
byucop
Muffler mounts are usually the prob. Other item to check is the mount clip for bag quick disconnect. Friend had one broke and it emitted a squeek at different rpms. Hard to find. Just lucky and saw bag move.
Old Jun 11, 2012 | 01:36 PM
oldschoolshovel's Avatar
oldschoolshovel
5th Gear
I had a chirp on my 2002 road king turns out it was my drive belt hope this helps
Old Jun 11, 2012 | 02:50 PM
Tom T-Bird's Avatar
Tom T-Bird
Originally Posted by davessworks
Try a little spray silicon on the rubber bushing on the muffler mounts under the bags . . . You may be pleasantly surprised!
+1
That fixed my problem.
Old Jun 11, 2012 | 03:28 PM
steelerdude1's Avatar
steelerdude1
I found that my noise was coming from the rubber bumper on the rear brake caliper mount squeaking on the swing arm. I tried soooooo many things until I found this by accident when doing a tire change. I dabbed a bit of bearing grease on the rubber bumper, and it went away.
When I was searching for the cause of mine, I found that most here were from the exhaust hangers. They are only $2 or so, try replacing them first.
Zoom1077
Milwaukee Eight (M8)
28
Oct 28, 2021 07:43 AM
3408pete
Samson Exhaust
Aug 12, 2012 12:03 AM
JWP79
Sep 27, 2010 11:27 AM
c50plus
Oct 14, 2009 06:32 AM
atexn4christ
Aug 25, 2007 04:57 PM
