SuperTrapp Vs Thunderheader
the supertrapp can be loud with an open end cap or quieted down with a closed end cap and adding more discs in the stack ( more on this below)
Typically the "core" is 2" in diameter- about 28 discs equals the flow through this 2" core.
the core is perforated with packing on the outside, it is important that this packing stay in place, otherwise gases can loose velocity and direction resulting in a reduced net flow.
the "closed course" open end cap is equal to about 10 discs for tuning purposes, the nightstick open end cap is slightly smaller opening equal to about 9 discs.
when discs are stacked, in profile the gasses are forced through a "W" shaped passage ( 360ş around) the W actually changes size which retains gas velocity and breaks up sound waves in the higher frequencies ( the packing is absorbing the low frequencies).
the more discs, more more net flow, less restriction and more noise--- and an emphasis on HP
the fewer discs ( with in a range) less flow, slightly more restriction and an emphasis on torque.
ST has tuning guides generally on a TC start at 18 or 20 discs and a closed cap, then go up or down 3 discs at a time, observing the changes- and dialing in the right combo for your motor, bike gearing and riding style.
when going on an extended road trip I usually add a couple of discs for a little more HP as I will be about 3000 rpms 99% of the riding day.
what i do:
built hipo 80" FXRP ST 2/1 closed cap 22 discs ( this lightweight bike has a 15% overdrive so I am tuned for torque to overcome the overdrive in town.)
stage 1 80" FLHTC w stock headers ST slip ons 14 discs rt side, 6 or 7 left side, closed caps
stage 1 09 FLHTC 96" stock header ST slip ons 16 rt/ 9 left closed cap.
recently replaced with take off nightsticks on the stock headers, same disc count, but running dummy discs on the left side ( so pipes are the same length) and closed caps up inside the open nightstick caps.
the volume of the bagger header system ( no cat) is itself an advantage for torque, and I am fine with the stock headers as the bagger motors i leave at stage 1.
mike
