Spark Plugs changed - Lean?
Old Jun 27, 2012 | 07:54 PM
iclick's Avatar
iclick
Originally Posted by criyi
Is this indicating lean?
No. Looks good based on photo IMO.
Old Jun 27, 2012 | 09:29 PM
criyi's Avatar
criyi
Originally Posted by angelrod
looks like your plugs is not properly tork . cause i can see the dirt on the treads all the way to the top.
They were surprisingly loose. I did fix that.
Old Jun 27, 2012 | 10:28 PM
harleymojoman's Avatar
harleymojoman
Default Ummm . . .
Originally Posted by Wild Card
to read a plug properly, 1st warm motor with old plugs, then install new plugs then the bike needs ridden to 3rd gear or higher with a full throttle run then pull the clutch and kill motor. pull plugs and look at them then. pulling plugs and trying to read after a normal cruise really doesn't tell you much about your tune.
the process is called plug chopping.
You forgot to tell him to scratch his right ear while shifting and blink 3 times after he kills the engine.
blackflame
Oct 25, 2014 10:04 AM
TWIN CAM 96
Mar 7, 2012 01:15 PM
congo_usmc
Aug 30, 2009 09:54 AM
LOU
Apr 26, 2007 10:31 PM
HDF Tech
Engine Mechanical Topics
Jul 2, 2005 03:48 PM
