stuck!!help with inner shifter p/n and tools needed
anyone know the part number of this shifter,bike broke on my way home from norcal and is stuck.sittin in a hotel tryin to figure out part numbers and the tools i need to buy to get it back goin,thanks.its inner shifter,it just snapped(cheap pot metal it looks like)here is a pic its the one circled i need,waitin for dealer to open now,then need to run to wally world and figure out the tools needed.
Are you familiar with Ronnie's Harley Davidson?
The web site has the microfiche with pictures of your bike by year and model.
If you have a 2000 Roadglide FLTR then the part you may need might be #29 but look at picture/diagram first...part number 33718-82..
* AFTER ADDING TO CART YOU WILL SEE PART NUMBER looks like a $40 part http://partsfinder.onlinemicrofiche....IFTER-ASSEMBLY
Is this the shift arm on the front of the case?
Have not seen anyone here broke it before.
Did the shaft bind in the case?
Where did it break?
I thought it was odd also..not an intense amount of strength required for that part..Maybe it was the ball/knuckle that broke since that is much more common but then you can always use a shoelace to wrap-it and get home...but he circled the arm? maybe it stripped the splines?
was inner shifter shaft in pic,b**** is older 2000 and was cheap thin pot metal.went to dealer and gave me a updated one that is much thicker,thanks guys for the help,got it fixed and safely back home
