Bagger wobble exposed!
Old Mar 10, 2017 | 11:33 AM
  #581
G92069's Avatar
G92069
This "death wobble" is not speed or vibration. It does not appear to originate from the front of the bike. It is a wobble from the rear end that causes a loss of traction. Over the past 40 + years, I have ridden everything from dirt bikes, street bikes, stretched rigid choppers, to this bagger/touring bike. The only similar sensation was the rear wheel hop I used to experience on my fat tire rigid.
When I first experienced it on my 2011 SG, I googled it. As described here and other places, this particular wobble is generally experienced on long, sweeping curves. The speed l experienced it varied from about 50 - 80. Low speed, no wobble..after the first few times I did not increase my speed above what I mentioned. The long, sweeping curve was on my way home from work everyday. The wobble occurred every time, without exception, though it did seem to lessen when I was in the number 2 lane.
I am very comfortable riding bikes, fast or slow. This wobble was/is very disconcerting. It feels like the rear end of the bike is going to slide right out from underneath you. A scary feeling for an experienced, 50+ guy, with a wife, 3 kids, and a mortgage.
The wobble is real, it is not imagined, nor invented by aftermarket parts manufacturers. I would say if you haven't experienced it, good for you. It still exists though. If you have it, give a stabilizer a try. Though I did not order the specific one the OP ordered (pm him for the name-just kidding, I did read the entire thread!), I did order one this morning.
That's my story and I'm sticking to it! Be safe!
Old Mar 10, 2017 | 11:41 AM
  #582
roussfam's Avatar
roussfam
Nope...dont have it
Old Mar 10, 2017 | 11:45 AM
  #583
danzio's Avatar
danzio
My wobble experience is much different. When I purchased my bike in Summer '11 with 19K miles it didn't have any wobble at all. Now I experience low speed wobble only when I have my Tour-Pak on.(Insert head-scratch smiley here).
I don't ride much with the Tour-Pak anymore so I haven't further investigated but since it has manifested over time I have to believe it has to do with some "wear" part of the chassis (motor mounts, swing-arm bushing or similar) is the cause. Otherwise bike is solid as a rock regardless of road type/condition.
Old Mar 10, 2017 | 12:33 PM
  #584
twinchrome's Avatar
twinchrome
Default Think I kindam solve my wobble issue.
It's due to my new rear tyre. Changed to a Michelin commander whereas the front tyre is abt 7mths old. Instead of 40psi, I pumped 38 psi for my rear n the wobbles is gone.
Old Mar 10, 2017 | 01:05 PM
  #585
roussfam's Avatar
roussfam
Glad to hear it, don't get the tour pack thing either
Old Mar 10, 2017 | 01:09 PM
  #586
roussfam's Avatar
roussfam
Funny how much of a difference a change of tire brands can make sometimes.
Old Mar 12, 2017 | 10:55 PM
  #587
twinchrome's Avatar
twinchrome
weird but am surprised too. Guess its a case of old and new tires combo that caused the wobble.
Old Mar 13, 2017 | 03:11 AM
  #588
grbrown's Avatar
grbrown
Wink
It's more complicated than that, which is why this thread was started! Tyre brands do have very different approaches to how they design and manufacture their tyres, so sometimes mixing them can cause problems, but in over half a million miles I have only had a couple of bad experiences (not on Harleys) and a long time ago.
Old Mar 17, 2017 | 03:45 PM
  #589
Gliden's Avatar
Gliden
The short version.
Bought bike in 09. No wobble
Few years later, wobble on right leaning sweepers or pulling power changing lanes.
Installed True Track AFTER....DOING MANY THINGS. Only thing that got rid of wobble was true track or trac or however it's spelled.
No more wobble.
Ever.
Old May 15, 2017 | 11:35 AM
  #590
ShiftyCapone's Avatar
ShiftyCapone
Hopefully you've had an opportunity to get some miles on that other stabilizer. How do you like it thus far?
I have a 2016 RGS that has, on several occasions to varying severity, gotten wobbly on sweeping turns. I would honestly describe it as more of a hinge effect where the front portion of the bike and rear wheel seem to be working against each other causing the *** end to wag back and forth. It is not the same as a speed wobble or "tank slapper" common on sport bikes. I have not changed any suspension components...yet. Obviously, I'd like to correct this issue as best as possible and the product I choose to do so will likely impact other future mods (oil cooler). So G92069, any input or experiences would be greatly appreciated.
