Bagger wobble exposed!
Anything I would have to look out for ... a longer rod end bearing set ... ground clearance? Has to be doable.
Sadly, the previous owner of my bike was a cheapskate who went for a Progressive.
Rough measurements ...
Well, this was the opposite of what I was expecting.
Excuse me as I only have a simple dial calliper, so I have to use its length (approx 9.25") + the measure of the depth measuring tip.
I measured across the top and bottom of the flats of the inside of the swing arm mount/passenger footplate brackets, again both top and bottom bolt hole.
Firstly, as I would expect, they were not equal distances, being out by about 18 thou/.5 mm from minimum to maximum.
However …
When I torque them up to around the maximum set by the manual (34-42 ft-lbs), the distance actually increased, not decreased.
In my case, I have STA-BO bushes, so it went; Bracket > Donut > Sta-Bo > Transmission > Sta-Bo > Donut > Bracket
Loose | Torqued
0.832 | 0.857
0.838 | 0.860
So it expanded … the transmission and bushes pushed the frame apart 22 to 25 thou.
I could not measure the bottom one.
Perhaps over the next few days, I'll dig a jack out and see how much I can expanded it apart (... within limits) if anyone can suggest any test. Obviously it's going to be rough but do have a dial gauge I can try and set up too.
(For the record, the Sta-Bos are recommend to fit with .005" clearance to the transmission ... but I can't see how they don't compress).
I think if I was the True-track guy, I'd pay someone to kick their asses. Even if that meant an intellectual property attorney.
Half-price though ...
Not sure how you make your measurements.. I'd expect that the donut would crush a little but the frame would also spread under the preload.. Adding preload to the rubber mounts helps to stabilize the chassis.
I then extended the depth measuring stem out to measure the distance between the end of the gauge's main scale and the bolt hole boss on the other side.
And repeated on the top and bottom of both bolt holes to check for unevenness.
Not highly accurate but enough to register some change and a starting point.
Of course I'd agree that frame flex is minor in comparison to both the rubber mounting issue ... but I would add the looseness of the swing arm pivot in the transmission which translates to quite a bit of movement at the end of the swing arm.
Hence my question what an ideal fit would be.
