Removable tour pack question....
Old Jul 30, 2012 | 07:46 PM
hattitude's Avatar
hattitude
Default Removable tour pack question....
I have a 2012 FLHTK. I've been toying with the idea of making the tour pack removable with the HD kit(s). I have three questions that have popped up while I have been researching this mod........
I have been told that when the tour pack is removed, you lose the ability to use the CB radio. Something about a part in the tour pack that the CB antenna needs to function properly. I'm not with the bike at the moment or I'd look in the tour pack to see if there's anything connected to the CB antenna. While I don't use the CB, I'm just curious about this....
Today, a Harley service manager said (I doubt this just because of the source) that converting the bike to a removable tour pack system takes 6 hours of labor.... damn, I've looked at the kit(s) and that seems high. I was thinking I could do it myself in about 4 hours, am I dreaming?
The same service manager also said that the limited radio is programmed for four speakers. He said that running it without the rear speakers connected will cause the bike to throw a code that will activate the check engine light..... That doesn't sound right at all.... I actually said, "Are you serious? A radio issue throws A CEL?" and he insisted that it's true.
I'd appreciate anyone with that mod to comment on these three questions...
Thanks in advance
Old Jul 30, 2012 | 08:33 PM
trailmaster308's Avatar
trailmaster308
I have a 2012 Limited EG. I had the stealer put the kit on because it was a major PITA per a good wrencher friend of mine.
If done right the CB and Radio antena just screw off with the supplied kit when your remove the tour pack. The rear speakers have a disconnect pin that is actually stuffed inside each speaker. Remove those, then just stuff your rear intercom connection under the seat.
I have yet to actually disconnect mine. If no one responds I will test the radio question this weekend.
Dealer never mentioned to me.
Old Jul 30, 2012 | 08:45 PM
riteway's Avatar
riteway
Thumbs up
I can try to walk you thru the removal and addition of detach (roughly)
Take off your saddlebags....
1. Remove tour pack from stationary mount. Lights/Speakers are quick disconnect. Unscrew antennas. 1.5 hours
2.Remove stationary tour pack bracket from bike.1/2-3/4 hour.
3.Install detach brackets on bike and mount detach bracket to tour pack. 1-1.5 hours
4. Install tour pack to bike and re-hookup lights and speakers 3/4 hour.
As far as antennas you should be able to screw them back on or get different brackets so they are mounted to SB rails or other spots. As far as radio antenna you could get an antenna that mounts under your fairing.
Good Luck... Not a hard job,the thing about doing a job yourself is you should feel good that the job was done right.Not that the dealer wont do it right but who knows..Also use locktite on those bolts for the detach kit that mounts to your bike!!
Old Jul 30, 2012 | 08:48 PM
mkguitar's Avatar
mkguitar
so- I have the FLHTC ( no cb, no rear speakers).
installing the kit took maybe 2 hours* going very,very slowly- checking and re-checking the work (as the instructions could have been more clear
I changed a bunch of the wiring to suit my needs ( I work with electronics)- and installed the am/fm radio mount down by the left saddlebag.
if you are at all handy--- NEXT TIME I will spare my self the expense of buying the kit from H-D.
My typical use is to put the tour pak on for weeks at a time, take it off for weeks at a time.
to bolt and unbolt the whole shebang takes only about 30 minutes a time.
and the wiring needs are the same either way
if you think you will be tour pak on/off many times a year, then get the kit.
for my needs, I coulda saved the cash.
Mike
*dealer labor rates are not "actual elapsed time" the rate is based on what they think they can bill for this service
Old Jul 30, 2012 | 09:07 PM
hattitude's Avatar
hattitude
Thanks for all the input...
I thought the 6 hours was pretty inflated. Based on what I've read here, I'll do the install myself. I've got the service manual and I'm pretty handy with my tools.
I will probably use the HD kit, only because I'd like to have the detachable sissy bar on, when the tour pack is off.
Has anyone had any experience with a check engine light when their rear speakers are not plugged in?
Thanks again for the info....
Old Jul 30, 2012 | 09:28 PM
Harsh1828's Avatar
Harsh1828
No check engine light will come on when you use the kit. Put one on my 06, only took the pack off twice in 6 years so it was not worth the money for me. Like the storage for stuff like a helmet, water botTles, etc.
Old Jul 31, 2012 | 01:22 AM
hattitude's Avatar
hattitude
Thanks...... I suspected that was a load of crap..
Old Jul 31, 2012 | 05:04 AM
Mathews2's Avatar
Mathews2
Had the kit on my 11( may it RIP). And have it on my 12. Never had or even heard of it throwing a code
MRKWMSN
Jun 24, 2014 09:15 AM
shovelhead FXEF
Screamin Eagle CVO Models
Oct 4, 2013 02:27 PM
EnglishAdam
Nov 6, 2012 05:49 PM
chris
Sep 18, 2009 12:04 PM
SKULLZZ44
May 5, 2008 08:28 AM
