What replacement battery for engine modified '09 FLHX?
Old Aug 5, 2012 | 07:47 PM
FLHXDAN's Avatar
FLHXDAN
Default What replacement battery for engine modified '09 FLHX?
Having trouble turning the engine after a 107" upgrade and stage 1 head work. Does anyone have experience using the higher cranking amp batteries?
Old Aug 5, 2012 | 08:06 PM
senna's Avatar
senna
Did you add compression releases when yo built the engine?
Old Aug 5, 2012 | 08:09 PM
dbell66253's Avatar
dbell66253
+ 1, if you upped the compression, the releases help a lot when starting the engine, otherwise the battery will be the cheap thing you will be changing compared to the starter.
jumpyrk
Engine Mechanical Topics
17
May 14, 2016 10:57 AM
tphillips
Apr 4, 2013 12:46 PM
Terrabella
Jun 10, 2011 06:59 PM
deathrattleshake
General Topics/Tech Tips
Feb 26, 2009 10:33 AM
bjornsson
Oct 22, 2007 07:29 PM
