FLHTCU wont start
Old Aug 15, 2012 | 07:40 PM
bboy57's Avatar
bboy57
2nd Gear
Default FLHTCU wont start
I have new battery, new FOB battery, tightened starter/battery cables. I can turn on the key, lights/radio/security lights alternate back and forth but starter button does nothing! No click, nothing. Changed out the brake relay with the starter relay(they are both the same numbers)...nothing! Any ideas other than taking it to the dealer. I live in Sebring, Fl and there are no dealers within 100 miles. Thanks
Old Aug 15, 2012 | 07:41 PM
Notgrownup's Avatar
Notgrownup
Check all your fuses...kill switch? on or off?
Old Aug 15, 2012 | 07:43 PM
bboy57's Avatar
bboy57
2nd Gear
All fuses good. Kill switch on! Tried em all!
Old Aug 15, 2012 | 07:48 PM
Bill03E's Avatar
Bill03E
You say that the security lights are flashing? turn signals flashing?
If so your alarm is active, and that disables the starter.
Old Aug 15, 2012 | 07:49 PM
bboy57's Avatar
bboy57
2nd Gear
how do i disable it? Or would changing the battery reset everything?
Old Aug 15, 2012 | 07:51 PM
bboy57's Avatar
bboy57
2nd Gear
Turn signal lights back and forth on. 2009 Ultra
Old Aug 15, 2012 | 07:59 PM
Armstronges's Avatar
Armstronges
Sounds like it's not seeing the fobs. Try to bypass the fobs with your pin number.
Old Aug 15, 2012 | 08:06 PM
Bill03E's Avatar
Bill03E
I know on my bike I sometimes have to retrain my bike to see the fobs, I do not know about the new bikes because my alarm does not auto arm.
Old Aug 15, 2012 | 09:15 PM
SMsgt Tom's Avatar
SMsgt Tom
I had this happen to my 07. Starter bolts were loose. Tightened them up to torque spec and it started right up.
Old Aug 15, 2012 | 09:52 PM
bboy57's Avatar
bboy57
2nd Gear
Default Got it fixed
Had to reset alarm! Turned ignition to ing, held both turn signals at same until code came up, then clicked to all "00000" and bam...started up! Taking battery off sets alarm to armed as default!
