Six speed ratios
Old Aug 19, 2012 | 07:07 PM
Challenger's Avatar
Challenger
Default Six speed ratios
Are the gear raitos 1 thru 5 the same on a six speed as a 5 speed?
For instance on my 5 speed I run 2900 at 70 no wind level surface. Is 5th gear the same in a six speed?
Old Aug 19, 2012 | 07:30 PM
nvsteve's Avatar
nvsteve
No. The ratios are higher in each gear in the 6 speeds. 07 and 08 bikes in particular. In 09 the rear pulley is 2 teeth more so overall gearing is somewhat closer to the 5 speeds but still taller.
Old Aug 19, 2012 | 07:35 PM
fffffish's Avatar
fffffish
At 70 I run 2650 in 6th
Old Aug 19, 2012 | 07:42 PM
mkguitar's Avatar
mkguitar
if you google
28_RatiosMPG-pg28
you will find a chart at the andrews cam website that has ratios, and MPH vs RPM data for Harley models the past 30 years.
the 5 speed vs 6 speed depends on whether the 6 speed is an "overdrive" with a .86 final or a "close ratio" with a 1:1 6th
mike
Old Aug 19, 2012 | 07:55 PM
perki48's Avatar
perki48
No they are not the same.
5th gear 5 speed =3.150
5th gear 6 speed dresser=3.407
5th gear 6 speed Dyna=3.307
Six speed info is directly from HD wedsite.
To my knowledge Harley has never made an "overdrive" trans.
Old Aug 20, 2012 | 06:54 PM
bigdumbnoitall00's Avatar
bigdumbnoitall00
6th and( 5th on a 5 speed) are 1-1,but the difference comes from the primary and final drive ratios,harley cheeped out the 6 speed it is not an overdrive,they lowered first -fifth.and made the final and primary taller.
Old Apr 17, 2020 | 09:08 PM
dochands's Avatar
dochands
What year, what model?
Old Apr 17, 2020 | 09:11 PM
dochands's Avatar
dochands
As the engines get bigger... more HP and Torque, they are able to handle higher gears and run at lower RPM at cruising speeds.
Old Apr 17, 2020 | 10:03 PM
Keithhu's Avatar
Keithhu
And as the threads get older.......
Old Apr 17, 2020 | 10:29 PM
dforeid's Avatar
dforeid
Hmmmm, another 8 year old thread.
TVtommy
Sep 21, 2009 12:08 PM
bigjohn1percenter
33
May 24, 2008 04:46 AM
rfranz1952
Mar 12, 2008 04:13 PM
mbjam359
Dec 27, 2007 04:23 PM
ATM67
Shovelhead
Aug 27, 2007 05:01 PM
