Engine revs high by itself...?
Old Aug 8, 2014 | 06:15 PM
Dew Me's Avatar
Dew Me
Originally Posted by Smokey Stover
My local dealers tech's ( part changers) replaced everything including the throttle body to the twist grip. Before I suggested ( info from these forums) they check between the back of fairing and gas tank. Sure as shiat pinched wires.right where the zip tie was too tight with not enough slack in wires, spliced in a few inches of wire all better.
Glad it was all under warranty.
This is what I think is going on. Or maybe is what I hope is going on. I had a chrome neck cover on and that is about the time my problem started. I finally made the connection and removed the chrome neck cover. I went from having the problem daily to many days/trips w/o it happening even once. But then it started up all over again and again is fairly consistent. I don't think it's a coincidence. I've moved the wires around though. There is no zip tie at all anymore as I removed it when originally adding the chrome neck cover and never replaced it. The is obviously a connection or I couldn't ride, so I can't really test continuity.
Old Feb 11, 2015 | 10:15 PM
Dew Me's Avatar
Dew Me
Old Feb 11, 2015 | 11:05 PM
mkguitar's Avatar
mkguitar
deleted
Last edited by mkguitar; Feb 11, 2015 at 11:07 PM. Reason: old threads die hard...
Smash
Oct 10, 2014 03:59 PM
Dew Me
Jun 5, 2014 10:23 PM
Matthew Wallace
Jul 8, 2012 03:07 PM
oldkarphart
Aug 13, 2010 05:29 PM
