Biketronics bt1002 question
Old Aug 25, 2012 | 06:13 PM
Harley Hound57's Avatar
Harley Hound57
Default Biketronics bt1002 question
Well i installed my Sony mexbt4000p with the biketronics bt1002 and every ting is working great except my AVC does not work, so i was digging around their website and i find a procedure for removing the AVC pin from the harley harness.
I assume i need to do this?.
Old Aug 25, 2012 | 07:18 PM
old v twin's Avatar
old v twin
Default AVC set up procedure
Have you done the AVC set up procedure as described by Biketronics?
Old Aug 25, 2012 | 07:20 PM
Harley Hound57
Yep a few times.
Old Aug 25, 2012 | 07:47 PM
old v twin's Avatar
old v twin
Default I did as well
Suggest you call BT on Monday.
I had to set mine a few times to get it to sync. Did not seem to be anything wrong with the unit, the procedure seems to be very particular.
On the plus side, if BT even thinks there is anything wrong with their unit they will ship out a new one and wait on you to ship the other one back.
Good luck.
Old Aug 25, 2012 | 08:32 PM
jjnoble's Avatar
jjnoble
Don't mess with the pins. It is probably the module. When I had one, it was finicky. and I had to hold the button down 2 or 3 times longer than the instructions said. Deviate from the instructions some, it will probably work.
Old Aug 25, 2012 | 08:37 PM
PistonPuller's Avatar
PistonPuller
Disconnect battery for a few minutes and reconnect
Old Aug 26, 2012 | 07:52 AM
1sweetglide08's Avatar
1sweetglide08
I had to do the same. It should work just keep trying...If not Biketronics has excellent customer service.
Old Aug 26, 2012 | 01:12 PM
vhmike73's Avatar
vhmike73
Good luck.
I've had to do this once already, and now my BT1005h is acting up...or rather NOT acting up (handlebar switches are completely NON-Functional with both my DSX-S200X and DSX-S100).
Bear in mind, they DO charge you $50 deposit to ship a new unit to you; it's credited back pretty quickly once they receive your 'bad' unit though. He had to change his methods as too many people were NOT sending back the old units.
Old Sep 10, 2012 | 03:17 AM
Mentalmadness's Avatar
Mentalmadness
A bit off topic but still about the AVC....How does it work really? I mean does it turn the sony radio down and then back up according to speed?
Old Sep 10, 2012 | 05:28 AM
kyote's Avatar
kyote
Yep....
dforeid
Audio Systems
Nov 27, 2018 08:49 PM
QNman
2014-2024 Touring Models
Jan 23, 2017 06:45 PM
DK's Limited
18
May 9, 2016 03:41 PM
Yellow Glide
Jan 22, 2015 11:48 AM
mikes99EG
Nov 21, 2005 12:34 PM
